B6 Brake Upgrade
thanks!!
Im sure this has been covered before, but do you know if Leon Cupra R brakes will fit but using the discs from an S4. As they are the same size discs and also from looking appear easier to get hold of compared to the S4 setup.
[Dec 8, 2011]
OK cool, just looked at them and also found just caliper for a B7 2.0T at £280 so a full front and rear setup for £350 should be a bargain.
OEM Brake UpgradesB6A4 1.8t- Same Caliper as B6A4 3.0
Front Rotor: 288x25
Rear Rotor: 245x10 or 255x12
To check size of rear rotor, remove and check part #:
8E0 615 601 P = 245x10mm
8E0 615 601 D = 255x12mm
B6A4 3.0- Same Caliper as B6A4 1.8t
Front Rotor: 312x25
Rear Rotor: 255x12
B5S4
Front Rotor: 321x30
Rear Rotor: 256x22
B6S4- Same Caliper as B7A4 & B7S4
Front Rotor: 345x30
Rear Rotor: 300x22
B7A4- Same Caliper as B6S4 & B7S4
Front Rotor: 320x30
Rear Rotor: 288x12
B7S4- Same Caliper as B6S4 & B7A4
Front Rotor: 345x30
Rear Rotor: 300x20
Dec 8, 2011
To fit the 320mm from the 2.0T B7 do you need the section of brake line that leads to the calipers from the B7, or do ours fit?
I'm running S5 Calipers and B6 S4 discs, best upgrade I've ever done
Sorry to burst your bubble but they are not even half as good as the later single piston calipers... Still better than the older 288/312mm brakes...
I had heard that but for what I paid for them and on the basis I'll be stepping up from 288s I would imagine I will notice quite a difference
I think you were better off with 312mm brakes, cheap and effective power upgrade with decent pads and discs for about 200 Bhp. For more stopping power then the 320mm and ATE hp2 calipers and good pads are good enough for 300 Bhp or there abouts. If you have a heavy car or in excess of 300 Bhp then the b7 rs4 is the next logical step for true plug and play upgrade. As with everything in life, stepping up a notch will cost more money so if you want to keep costs sensible then stopping at the 320mm brakes is the best value for money !
[Dec 8, 2011]
Front Rotor: 288x25
Front Rotor: 312x25
Rear Rotor: 255x12
B5S4
Front Rotor: 321x30
Rear Rotor: 256x22
Front Rotor: 345x30
Rear Rotor: 300x22
Front Rotor: 320x30
Rear Rotor: 288x12
Front Rotor: 345x30
Rear Rotor: 300x20
Dec 8, 2011
Does anyone know the answer to this?
There is someone selling a pair of these calipers local, but there are no brake hoses with them. If I buy them I would like to have everything I need to fit them before I've stripped one down to find out mine don't fit, as TPS isn't open at the weekend and I doubt they'll stock them on the shelf.
Vw touareg 4 and 6 pot brakes fit with a little modifying.
330 or 350disks. Dirt cheap on ebay and unbadged brembos as well
last set i picked up where £100 6 pot 350mm.
