stu22uk
Hello everyone,
Im desperate for some good advice/help. Been reading on this subject for some time now and watching from the sidelines - some very knowledgeable people on this forum and I would be eternally grateful for some educated input.
Problem - Only the scroll wheels on the mfsw work, nothing from "MODE" or "SPEECH" not even the beep!
I have RNS E and audi blutooth and have coded the modules (i believe) correctly for uk ;
Telephone (audi bluetooth) - soft coding - 0011702
Navigation - soft coding - 0301715
steering wheel - soft coding - 05041
I do not have BOSE therefore didnt need to move pins on the rnse plug. I have ran the mic through the rnse (mic in - mic out) and can confirm the wiring is correct as I can still use the bluetooth telephone with rnse as I always did.
I aquired the following parts to allow for the mfsw retrofit -
SWCM - 8E0 953 549 Q (I suspect this may be the problem - i know most people use the "R" variation however I read that both "R" and "Q" are "compatible".)
S/C Ring - 4E0 953 541 A, - It has 12 pins where it should and the "New" shaped socket on the rear for which I had to change my original plug (as expected).
In VAG COM I get the following fault code in the steering module -
Address 16: Steering wheel
Control Module Part Number: 8E0 953 549 Q
Component and/or Version: Lenksáulenmodul 0601
Software Coding: 05041
Work Shop Code: WSC 06335
2 Faults Found:
01301 - Control Module for Voice Recognition (J507)
49-00 - No Communications
01794 - Control Module - Incorrect Chassis (VIN) Number
Ive since taken care of the "incorrect chassis" fault. Its the no comms from voice recognition that reoccurs no matter what I try.
No other fault codes in telephone of nav.
Car Info - 2001 b6, K line diagnostics - no CAN (at least not with VAG COM)
Again I really appreciate anyone willing to devote a little time to helping me out with this...
I dont normally request help in forums - not because Im a social ****** but because I find if you hunt hard and long enough the information is usually there. Ive seen countless posts with moderators going berserk because people just ask repeat questions and wont search for things. THATS NOT ME!
2 Faults Found:
:thumbsup:
