boya
I fancy giving this a go but just wanted to double check, in the pic do I remove the pipe with the White sleeving under the egr and blank it at both ends or am I completely wrong lol!
correct heres a photo of fitted plate![]()
Ahhh I thought the pipe was removed all together and a blanking plate made lol!! So basically a thin piece of steel to slide in the gap is all I need with a couple of holes in it for the bolts?
Does the actual EGR VALVE need to be cleaned for this mod to be effective or do you just apply the blanking plate ?
I have just ordered a blanking plate for mine. Does it effect the fuel economy at all?
Does the vacuum pipe need removing or can it be left connected as in the pic above with the plate fitted. I have fitted the plate but also removed the pipe which I think is the reason my engine warning light is on.
