Concert 'CD ERROR' in 2007 S3
DaveyB
No misfires.
UK
As the title suggests I have encountered an error!
My standard double din concert system has always worked fine for the last year or so I have had the car but recently whilst playing 'CD's (which is very rare as I have the crappy ipod dock) the CD freezes and won't eject. 'CD Error' and 'service' flashes up.
A quick web search reveals that this is a 'known; fault but I havent found anything similar on here. The HU is the front loading 6CD version.
What are my options seeing as the car is 2 months out of warranty? Drop kick it up the garden and replace with something else?
Thanks in advance
Hard to say whether it will be cheaper to fix than replace (off the bay / second hand). Problem is, it could happen again with a second hand replacement.
I'd imagine a local electronics firm may be as likely to fix it as Audi as usually it will be laser alignment or failure which isn't a complex fix as most drives are made by a handful of suppliers (philips / Sony etc.).
Have you tried running a TDK laser lens cleaning CD through it just incase it's fluff / dust?
Cheers Warren - those were my thoughts exactly with a replacement, i.e it could happen again if its a design/manufacturer fault.
I will give the TDK idea a go as there is every chance it could be a bit dusty because of the design of the unit. It can't have seen much action due to the mileage/age of the car so its not as if it's 'knackered' so to speak.
Hi DaveyB,
I had similar problem with my sat nav-disc that loads into the front of my RNS-D, it said "cd error" same as yours.
I tried disc cleaner etc but had no luck.......
So i took the unit out, took the top off, stuck a cotton bud in my mouth to dampen it slightly and guided it in very carefully onto the laser and twisted. The cotton bud went black!!!!! I kept doing it until cotton bud was clean and with the last cotton bud i used it dry.
Put the unit back together, put disc in and loaded first time. Never had a problem since :)
Hope this fix will solve your problem to
Paul
Excellent stuff Paul - great to have another plan of attack!
