Hopefully some of you can assist me in this predicament, as after 9 months and a shed load of cash, I'm coming close to the end of mytether.
Firstly some great fault codes;
17544/P1136/004406 - Ross-Tech Wiki which is Fuel trim bank 1, system is too lean.
16955/P0571/001393 - Ross-Tech Wiki Brake Light Switch (F): Implausible Signal.
18010/P1602/005634 - Ross-Tech Wiki Power Supply B+ Terminal 30: Voltage too Low
The recurring ones (which have also cost me enough to sort out)
16396/P0012/000018 - Ross-Tech Wiki Bank 1: Camshaft A (Intake): Advance Setpoint not Reached (Over-Retarded)
16727/P0343/000835 - Ross-Tech Wiki Camshaft Position Sensor (G40): Signal too High
The last two I have been back and forth for since February 2011, and I had the cam shaft tensioners and chains changed along with a cam belt which was not tightened properly by a previous garage when the last owner had it. And even after this was carried out, problems persisted and this carries on. I have been to another VAG specialist who stated he couldn't find anything wrong.
The former three, especially the lean message, again nothing could be found which may have caused the issue. I'm running out of ideas/patience/money to keep trying to fix the problems; I just want to enjoy my car as I have always wanted. The car doesn't idle properly, and engine management light is on too intermittantly. I thought it may be a dodgy remap? I took the car to AMD in thurrock to see if it had a remap which they confirmed. However they didn't know who provided or what brand was the remap.
Help me please!!! Has anyone encountered this? If so what did you do to remedy this?
Thank you in advance.
Seán
Seán
