Andy123
This isnât so much of a build thread in progress but more so what I have been up to with the s3 the past year. It is nearly finished and back on the road. I was originally selling the car before I decided to rip it apart as I wanted something new but ultimately wasnât too impressed with other carâs I tried and decided I fancied a bit of a project so kept it and proceeded to tear it to pieces.
As standard it was a black 01 plate with a few mods that the original owner had done: AMD remap, uprated haldex, forge re-circulating valve and that was mostly it.
All of the work done on the car has been done by myself bar a couple of bits which I didnât have the equipment to do myself: powdercoating wheels etc.
I originally was going to just work on the engine and chassis but decided in the end to repaint the car and alter a few other parts to get it looking how I wanted. I have only put a fraction of the pictures up which I have taken but it will give you an idea of what has been going on the past year. Brief spec list, most likely with parts missing which I have forgotten to add:
Paint change to vw candy white with black surrounds and roof
Garrett gt3071r turbo
SEM intake
R32 throttle body
Additional inline pump
Aquamist water injection
Built AEB head with supertech valves, springs, new guides etc
IE rods
Custom turbo manifold
Custom 3" downpipe and exhaust
630cc injectors
Unitronics 630cc tune
Custom intercooler
330mm discs + 6 pot calipers
Zeitronix AFR digital display with egt, map and oil pressure sensor
MBC
Sachs performance clutch kit
Fidanza flywheel
Kw suspension
r32 roll bars
A lot of cutting and chopping and custom parts.........
I started it up for the first time a few days ago and have attached some videos at the bottom. They arenât the best videos as they were taken on my phone. The first video has an annoying noise coming from the secondary water pump but it goes away after I disconnect it. I need to figure out what is wrong with it and test it later to see if it is still working correctly.
Anyway I will update pics and reply to any comments people may have so feel free to comment on it.
The car when I was going to sell it:
Last June when I began to take it to pieces:
Block and piston surface cleaned up:
New IE rods:
Original head and replacement AEB built head with supertech valves,springs,new guides etc
New rods in:
Engine built up, new timing belt,pump etc.
Body rubbed down in preperation for paint etc:
New rear bumper I made to accommodate the exhaust I was making:
New kw suspension and r32 roll bars installed:
Fidanza aluminium DM flywheel:
Sachs performance clutch and pressure plate:
Flywheel and clutch in place:
This is only part 1 of the thread, I will be adding two more posts but had to do them individaully as I couldn't upload the amount of pictures all on one post. Please don't post anything or reply until I have uploaded the other two parts so that I can keep them together. Thanks Andy
SEM intake
R32 throttle body
IE rods
630cc injectors
Custom intercooler
MBC
Fidanza flywheel
Kw suspension
r32 roll bars
New IE rods:
New rods in:
