the car has the a.b.s light on and a yellow circle with a yellow triangle in the middle any help would be great as im looking to buy the car cheap i know the a.b.s will be a sensor but a ant got a clue wot the other light can be thanks for looking
If its *actually* a 2001 car chances are it was manufactured in the middle of 2000. If it is pre facelift it doesn't have ESP, but does have an ABS light which physically says A.B.S.
Yeah, ok, but regardless of when it was built, if it doesnt have the ESP switch on the dash, thats the switch that allows you to turn it off, then surely its not got ESP.If it is registered in 2001 it could actually be a 2002 MY car, they start building them after their summer break.
ESP equiped cars have a switch on the dash board, if you press it the word ESP lights up on your display, it means its switched off. If you have an ABS fault code etc then the EPS is probably not working as well.
DC
Badman!![]()
