Hi guys,
I hope someone can give me some ideas here. I just got back from my honeymoon and found that my speedo cluster is dead - only sign of life is a flashing handbrake light.
The car drives fine, radio, aircon etc all work 100%. It's just the speedo cluster looks like the car is turned off.
I ran a VCDS scan which reported some errors: (I'm aware of the fan malfunction and am about the get that fixed)
Saturday,30,April,2011,12:18:14:24995
VCDS Version: Release 908.2
Data version: 20100326
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 7D
VIN: WAUZZZ8P44A119475 Mileage: 128980km/80144miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 G HW: 028 101 136 4
Component: R4 2,0L EDC 0000SG 5705
Revision: 12345678 Serial number: AUX7Z0CDFN40BP
Coding: 0000072
Shop #: WSC 06435 000 00000
2 Faults Found:
18354 - Control Module 1 for Coolant Fan: Defective
P1946 - 000 - -
Freeze Frame:
RPM: 777 /min
Torque: 22.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.98 V
Bin. Bits: 11000100
Temperature: 56.7°C
Duty Cycle: 9.6 %
18617 - Engine Coolant Temp Sensor on Radiator Outlet (G83): Signal too High
P2185 - 000 - - - Intermittent
Freeze Frame:
RPM: 1701 /min
Torque: 8.0 Nm
Speed: 61.0 km/h
Load: 7.1 %
Voltage: 13.91 V
Bin. Bits: 11000000
Temperature: 88.2°C
Temperature: 75.6°C
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0103
Coding: 0023686
No fault code found.
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 D HW: 8P0 820 043 D
Component: KlimavollautomatH12 0150
Revision: 022432 Serial number: 8P0820043D
Shop #: WSC 00000 000 00000
1 Fault Found:
01177 - Engine Control Unit
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 112
Mileage: 128984 km
Time Indication: 0
Date: 2011.04.28
Time: 01:14:47
Freeze Frame:
ON
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 A HW: 8P0 907 279 A*
Component: Bordnetz-SG 1.0 H30 0501
Revision: 00030000 Serial number: 00000000388376
Coding: A1885F00AA141000000000000000000000
Part No: 8P2 955 119
Component: Wischer WWS Audi350 0130
Coding: 16711696
Shop #: WSC 00000
9 Faults Found:
02104 - Light Detection Sensor (G399)
010 - Open or Short to Plus
01330 - Central Control Module for Central Convenience (J393)
004 - No Signal/Communication - Intermittent
01331 - Door Control Module; Driver Side (J386)
01335 - Drivers Seat/Mirror Position Control Module (J543)
01332 - Door Control Module; Passenger Side (J387)
01320 - Control Module for Climatronic (J255)
00483 - Control Module for Auxiliary Air Heater
01341 - Control Module in Instrument Panel On Comfort CAN (J285)
00466 - Control Module for Steering Column Electronics (J527)
Address 15: Airbags Labels: 8P0-959-655-84.lbl
Part No SW: 8P0 959 655 E HW: 8P0 959 655 E
Component: Airbag 8.4EDmin H00 0130
Coding: 0010102
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 A HW: 1K0 953 549 A
Component: Lenksäulenmodul 012 0030
Coding: 0000012
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 930 F HW: 8P0 920 930 F
Component: KOMBIINSTR. VDO H25 0110
Revision: D07 Serial number: 224DCD07029694
Coding: 0004803
Shop #: WSC 01333 996 64399
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 B HW: 1K0 907 951
Component: Gateway H08 0090
Revision: 08 Serial number: 2400103B179596
Coding: 3D0F0B42070101
1 Fault Found:
00381 - Databus Instrument Cluster
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 1
Fault Frequency: 1
Reset counter: 151
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Revision: D07 Serial number: AUX7Z0CDFN40BP
Shop #: WSC 01333 996 12757
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN1.lbl
Part No: 8P0 959 801 A
Component: Tuersteuerger. H10 0010
Coding: 0000016
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K2 909 144 E
Component: EPS_ZFLS Kl.10 1202
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433
Component: KSG H02 0040
Coding: 198800186D280F0FC8DAC67000
Part No: 1K0 951 605 A
Component: LIN BACKUP HORN H01 1201
Part No: 1K0 907 719
Component: Neigungssensor 002 0002
Part No: 8P0 951 177
Component: Innenraumueberw.H03 0010
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P3 035 382 HW: 8P3 035 382
Component: AB2 SUBWOOFERBOXH23 0100
Revision: 00001 Serial number: 10000001089764
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN1.lbl
Part No: 8P0 959 802 A
Coding: 0000016
Address 56: Radio Labels: 8P0-035-1xx-56.lbl
Part No SW: 8P0 035 186 HW: 8P0 035 186
Component: concert II EU H53 0060
Revision: 07S Serial number: AUZ2Z3C1742411
Coding: 0001001
2 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 3
Reset counter: 145
Freeze Frame:
Bin. Bits: 10
01299 - Diagnostic Interface for Data Bus (J533)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 145
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 C HW: 1K0 963 235 C
Component: PTC-Element 0404
Revision: 00600000 Serial number:
End ---------------------------------------------------------------------
Any help or suggestions would be greatly appreciated.
Thanks in advance!
Adam
Chassis Type: 1K0
Coding: 0000072
2 Faults Found:
P1946 - 000 - -
Freeze Frame:
RPM: 777 /min
Torque: 22.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.98 V
Bin. Bits: 11000100
Temperature: 56.7°C
Duty Cycle: 9.6 %
Freeze Frame:
RPM: 1701 /min
Torque: 8.0 Nm
Speed: 61.0 km/h
Load: 7.1 %
Voltage: 13.91 V
Bin. Bits: 11000000
Temperature: 88.2°C
Temperature: 75.6°C
Coding: 0023686
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 112
Mileage: 128984 km
Time Indication: 0
Date: 2011.04.28
Time: 01:14:47
Freeze Frame:
ON
Coding: 16711696
Shop #: WSC 00000
9 Faults Found:
Coding: 0010102
Coding: 0000012
Coding: 0004803
1 Fault Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 151
Coding: 0000016
Coding: 0000016
Coding: 0001001
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 145
Freeze Frame:
Bin. Bits: 10
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 145
Thanks in advance!
Adam
