Mi11ar
http://item.mobileweb.ebay.co.uk/viewitem?itemId=261091309718&index=0&nav=WATCHING&nid=11656833521
Found this for cheap.. is this the right size then?
I used a 70-80mm and it fitted like a dream
Must have been a large 80mm then... as the one I bought had no chance. The link above is spot on, I ordered mine from the place linked earlier in the thread
What do I do with the heat sink looking cable?
This just fits with an 80>70mm reducer, had to work hard to get that focker on! Worth it for a nice tight fit (that's what she said).
Mine is clipped in nice and tight, there is definitely a bit more poke from doing it and it inspires my heavy foot with the roar. It's still subtle enough to cruise by unnoticed, especially near home where you don't want to be labelled as a 'boy racer' especially as I'm not a boy now
I didn't have to slit it, just sit it on something sturdy and get about 3mm in on one side, then squeeze towards the other side to get that side in, then slowly push harder to get it all the way in.
I'll continue reading down the 'must do mods'- I have some s3 callipers so need some pads to go in them, on the shopping list for this week!
Believe Tuffty put the OEM box around a jetex cone filter but wasn't entirely pleased with the results so swapped back to a panel filter
Oh...Could've sworn I heard him say that in another thread...perhaps I am mistaken!! I'm sure Tuffty will be along shortly to reprimand me![]()
tuffy what is this bigger blue filter?? me likey!!![]()
I just went direct too Honda for mine £20 all in! I do have a question tho what material are your s2000 filters made of? Not the actual filter but the body of the filter is it hard plastic? If so how do you make it fit an s3 is mine doesn't fit all that well?
Did this a while ago now to my S3, anyone else notice like a hooting sound like an owl if you're balancing the throttle - say for example on a motorway cruising at 70-75? Is this normal?
I was thinking it might be due to the revs sitting on the spool point of the turbo ~2750RPM ish. And the diverter valve then recirculating the boost straight away as the throttle is neither held fully on nor lifted fully off. Therefore the DV is in a open state as the revs and throttle are kept constant. Could this be correct?
