Flight 666
HI guys My S3 does appear to be sluggish and has no real turbo kick.My car is the BAM engine has 99k miles and standard in every way.You can hear the turbo spool up but then you dont feel any real power from it.Turbo sounds fine no odd noises but you cant feel the power at the same time as the spool up noise.Cant find/hear any leaks etc.Could the standard DV be duff and leaking air back into the system and where else is is worth investigating if this is not the problem.Other than this the car runs spot on.How much power should I be feeling when it comes on boost as I had a Standard uk Impreza before the S3 and there is quite a big difference in the power delivery for two 225hp cars..Thanks for any pointers..
