2001 Audi A4 - no aircon
Ricky
South London
Recently bought an A4 Avant and the aircon doesn't work.
Are there any aircon specialists around the Croydon/Surrey/South London area you guys know?
What parts are likely to neeed replacing and how much £££ should i expect to budget for?
cheers
Rick
The best advice I can give is to go to Kwik-fit to get the system serviced. If there's no refigerant in it then it won't work. Kwik-Fit will try to fill it but if they can't there's no charge. They may be able to give you a fault indication too which should help with your second question.
I'll try this as a first step then.
I've just spotted your Aircon FAQ's in your sig....very, very helpful. Will be saving that as a favourite.
Thanks :thumbsup:
hi ricky
have you tried all your fuses related to your air con, if you need any parts try autoairconparts.co.uk as these were far cheaper than the stealers regently for myself on parts that i needed. Hope this helps or at least saves you some money if you need any parts.
