- Joined
- Dec 24, 2006
- Messages
- 4,170
- Reaction score
- 1,161
- Points
- 113
- Location
- Co.Antrim
- Website
- www.reallymeansounds.com
Anyone any experience in the below?
http://wiki.ross-tech.com/wiki/index.php/18359/P1951/006481
http://wiki.ross-tech.com/wiki/index.php/01274
http://wiki.ross-tech.com/wiki/index.php/01739
http://wiki.ross-tech.com/wiki/index.php/00929
VCDS Version: Release 10.6.3
Data version: 20101206
Sunday,10,April,2011,17:54:34:32181
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 7D
VIN: WAUZZZ8P54A083683 Mileage: 168380km/104626miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 G HW: 028 101 136 4
Component: R4 2,0L EDC 0000SG 5334
Revision: 12345678 Serial number: AUX7Z0C8FNA05O
Coding: 0000072
Shop #: WSC 79431 024 394950
VCID: 2759957DEF6B
2 Faults Found:
18359 - Radiator Fan 2 (V177): Movement Restricted / Jammed
P1951 - 000 - - - Intermittent
Freeze Frame:
RPM: 1407 /min
Torque: 6.0 Nm
Speed: 25.0 km/h
Load: 0.0 %
Voltage: 14.29 V
Bin. Bits: 00000100
Temperature: 61.2°C
Duty Cycle: 25.1 %
18358 - Radiator Fan (V7): Movement Restricted / Jammed
P1950 - 000 - - - Intermittent
Freeze Frame:
RPM: 1806 /min
Torque: 92.0 Nm
Speed: 46.0 km/h
Load: 26.3 %
Voltage: 14.52 V
Bin. Bits: 00000000
Temperature: 35.1°C
Duty Cycle: 9.6 %
Readiness: 0 0 0 0 0
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 HW: 8P0 820 043
Component: KlimavollautomatH11 0130
Shop #: WSC 00000 000 00000
VCID: E9DD5345B9FF
1 Fault Found:
01274 - Air Flow Flap Positioning Motor (V71)
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 3
Fault Frequency: 56
Reset counter: 31
Mileage: 160157 km
Time Indication: 0
Date: 2010.09.13
Time: 13:42:55
Freeze Frame:
Voltage: 14.30 V
Temperature: 19.0°C
(no units): 69.0
(no units): 32.0
Temperature: 17.5°C
Address 15: Airbags Labels: 8P0-959-655-84.lbl
Part No SW: 8P0 959 655 F HW: 8P0 959 655 F
Component: Airbag 8.4ED H01 0130
Coding: 0011602
Shop #: WSC 06435 000 00000
VCID: 45853FF57527
1 Fault Found:
01739 - Crash Sensor for Front Airbag; Pass. Side (G284)
011 - Open Circuit - MIL ON
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN1.lbl
Part No: 8P0 959 802 A
Component: Tuersteuerger. H10 0010
Coding: 0000048
VCID: 3A7F5C090CD9
1 Fault Found:
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
008 - Implausible Signal - Intermittent
Address 56: Radio Labels: 8P0-035-1xx-56.lbl
Part No SW: 8P0 035 186 HW: 8P0 035 186
Component: concert II EU H53 0060
Revision: 07S Serial number: AUZ2Z3C1484946
Coding: 0001001
VCID: EFE93D5D871B
1 Fault Found:
00858 - Connection; Radio ZF Output to Antenna Amplifier
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 25
Mileage: 168191 km
Time Indication: 0
Date: 2011.04.03
Time: 16:46:06
End ---------------------------------------------------------------------
The airbag/crash sensor fault aparently popped up after a blue tooth kit was fitted if that helps any?
The radiator fans run constantly so they are not jammed but them being on tells me that there is a problem.
Chassis Type: 1K0
Coding: 0000072
VCID: 2759957DEF6B
2 Faults Found:
Freeze Frame:
RPM: 1407 /min
Torque: 6.0 Nm
Speed: 25.0 km/h
Load: 0.0 %
Voltage: 14.29 V
Bin. Bits: 00000100
Temperature: 61.2°C
Duty Cycle: 25.1 %
Freeze Frame:
RPM: 1806 /min
Torque: 92.0 Nm
Speed: 46.0 km/h
Load: 26.3 %
Voltage: 14.52 V
Bin. Bits: 00000000
Temperature: 35.1°C
Duty Cycle: 9.6 %
VCID: E9DD5345B9FF
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 56
Reset counter: 31
Mileage: 160157 km
Time Indication: 0
Date: 2010.09.13
Time: 13:42:55
Freeze Frame:
Voltage: 14.30 V
Temperature: 19.0°C
(no units): 69.0
(no units): 32.0
Temperature: 17.5°C
Coding: 0011602
VCID: 45853FF57527
1 Fault Found:
Coding: 0000048
VCID: 3A7F5C090CD9
1 Fault Found:
Coding: 0001001
VCID: EFE93D5D871B
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 25
Mileage: 168191 km
Time Indication: 0
Date: 2011.04.03
Time: 16:46:06
