might leave then and just go for the 007p cheers tufftyPlenty of threads discussing this type of valve... wouldn't bother... they can lead to engine running issues as they bleed metered air when they dump and don't sound any louder than a 007p with a panel filter and a remap... no valve will sound particularly 'whooshy' without a remap anyway as there isn't enough boost pressure to make that much noise...
....Always bad replies when Split-r is mentioned but it still out sells the 007p...
right ok, so ive got a split R, should i look at taking off the trumpet and fitting the blanking plate that it comes with?
will that be better for my car?
i was advised to go for this over the 007P by PSI tuning.. seems they were talking ******** which was nice of them
only thing i find is now and then i get a fault on vag com saying pressure drop between turbo and throttle valve
good look
If Bill Paul and Welly say to use the 007p, I would go with that...
I would..but ive got the split R,
The split R obv has to output holes,one for recirc and the other for atmospheric through the trumpet.one is slightly bigger and allows more air through,so if i put the trumpet on the bigger one it makes the whoosh louder, and quieter on the other hole.
I realy dont know how to set it up best. Whether to use the trumpet or blanking plate, which hole to put the recirc pipe on, and how many clicks to turn the adjuster..
Wish i got the simple 007P now![]()
my split r sounds great mate not changing it either iv got trumpit on
set up have it on its side flat forge badge facing bonet the opisit site to that
fit into the tip then your turbo intake pipe these a thick pipe coming off that
put that into the bottom of your split r and the trumpit on the hole that left mate
spoke to someone who worked at forge and they said set to 22 click non mapped car
and 25 mapped car turn clock wize
007p running inline with a jetex cone filter, DV relocation kit and stripped out engine, sounds the nuts.
That took me almost five minutes to read.
Well Said Tom, i personally dont like forge, there gear is good, but way overpriced, and if they endorse the split-r what other crap are they selling? i think they have made this over complicated to set up as a get out clause for it been erm ...not so good, i.e. user error.
I thought the TIP stood for Turbo Intake Pipe? So you've fitted it to the TIP twice? Or am I going mad?
Our single best selling product, our 007P bypass/diverter valve. The ORIGINAL piston-based direct replacement valve for the Bosch 710 series of valves found on numerous OEM turbo applications....
Tuffty
Fairplay u must have the most boring life all u seem to do is be on here posting.................
...and you are right... I don't have much of a life lol...
