I run maf less on my s3 lot better for the air intake as it can be made bigger and stay that size all the way to the turbo
My vote goes to MAFless setup.
I remember when I went that route with my Mitsubishi EVO VI TME
id leave it up to the tuner. and what they think will be best.
You can always fit a bigger maf housing to suit whatever size intake you want to run, S4/RS4/RS6 maf housings etc. are all huge. And its not difficult for a tuner to calibrate for what ever size, whilst retaining the refinement and safety of having that extra sensor.
I have an rs4 maf housing and its a 3.5 inch intake allll the way to the turbo. More than adequate for my setup.
Tuffty i believe is using a 4 inch intake with similar size housing.
Thanks for your reply it seems rather expensive but i guess its a small price to pay to remedy the clogged up valves if it turns out that it works.
Im sure the smell could be fixed if it ever bothered you by extending the filter away from the engine bay or into the flow of air under the car although personally i quite like the smell of hot oil..
Im going to look into doing this myself now there does seem to be a few companies making these covers.
Alex sorry for the off topic but can you guys please smell your oil caps for me?
Does it smell like gasoline?![]()
Hahahahhaha no pun intended thereThis sounds like some sort of fetish.....
In any case,I don't need to smell my oil cap,as the catch can takes care of that need for me...
(OK...yes it does have a bit of a gasoline smell to it,but not like when I sniff the petrol filler......which I only do very occasionally now,as I'm trying to get over that one...)
I can see some of that stinky beige liquid residue in my catchcan too.
But seriously, that thing looks huge! That or the foam packing whatsits in the picture are very small
As much as I can't take him seriosuly, Clarkson is very correct on one subject - more power is good!
What inlet manifold are you running alex ?
Hahahaha leshkin that turbo will suck the ozone layerI swear... This thing looks like it will disrupt the spacetime continuum, once spooled up!
Are you sure it won't accidentally suck in a bird or a small animal?
When all said and done what sort of power and torque figures are you expected Alex?
