kitpayne
My S3 has serious boost issues, its like its missing but i'm sure its boost related!!
Is There any more info on this clutch switch, as i think it causes over revving? between gear changingN75 will account for your boost problem. If non functional, you will run actuator ppressure all the time.
The clutch switch will account for jerky gear changes, as the engine uses the clutch switch for rev matching.
It resolved my over rev problem in between gears during changes, when I replaced mine.
No fault codes? What gear did you do the run in?
Looks like actuator pressure so you are either in limp mode or there is a prob with the N75... where it goes to '0' duty cycle it looks like it may be hitting limp mode at that point...
Isnt he just off the throttle at that time.
Your specified vs actual boost is good but it requesting for low boost, wouldnt this be down to the MAP sensor.
Nathan
Welly did it completely stop the problem?
MAP sensor has nothing to do with requested boost at all. Requested boost is what the ecu requests, the MAP sensor delivers the data on actual pressure.
Ye, but to get the correct boost doesnt the ECU need to know the manifold pressure to get the right fuel mass to get the best air/fuel ratio, correct me if im wrong.
Nathan
Ye some cars dont have MAF sensors though and use MAP sensor to know the manifold pressure so the ECU knows what the fuel mass should be and tells the ECU how much air is being drawn in to get a stoichiometric of 1. So if the map sensor is giving wrong data the car would run lean as the manifold pressure is less so less fuel will be added and boost could be limited or lowered by the ECU. I maybe worng but thats how I understand MAP sensors.
Its probably not the OP problem but thought I would suggest it as his car is requesting low boost.
Nathan
Nathan
