Just change the fronts , none of the tyres wear even it always either front or rear dependant on what you changed lastAudi service say my front tyres are worn.
How do i change these ive seen people say axel at a time and all 4 at once and all the rest.
i could spread to axel but all 4 thats gonna be pricey.
You make full lock turns far less than you drive in a straight line.I agree, my theory has always been that the discrepancy between the front and rear wheels is more when you turn on full lock in a car park than it ever would be having differently worn tyres.
All the tyres are wearing together, at slightly different rates, so the differences in rolling radius are small.paul20v said:if you think about it as well you only wear 6.4mm off your tyres in there whole life if this has an effect on rolling radius you would be hard pressed to measure the difference
If causing damage to the centre diff isn't an issue why do Audi Breakdown (RAC) nor recover quattros using a "spectacle"?
If it was an "open" differential then what you say is true, but it's not an "open" differential.The centre differential is just that, a differential, it's whole purpose in life is to cope with differences between wheel speeds isn't it?
Because if your using a spec lift 2 wheels are locked when the others are turning at whatever speed the car is being towed at !If causing damage to the centre diff isn't an issue why do Audi Breakdown (RAC) nor recover quattros using a "spectacle"?
.It also doesnt mean you know everything ,i could also say ive been working on and running quattros of all types for 21years so i know nothing too ,OK you have it your way.
I guess working for a car design consultancy means I don't know anything...
