Drivers Window still wont work
Okay, here's a little update. I got the wire clip on, I put the door card back on, turned on the car and I have nothing working on the drivers side switch(window wind up/ mirror movement) before it was just the drivers side window not moving.
I dug out my laptop with VCDS and it said it had an hour battery left, though okay I'll probably get a scan, started the scan near the end it cut out but got the initial results without clearing. I have the laptop on charge now, I'll later clear and rescan. Could it be a fuse?
1 Fault Found:
01331 - Door Control Module; Driver Side (J386)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 245
Mileage: 144789 km
Time Indication: 0
Date: 2024.01.23
Time: 17:09:14
Freeze Frame:
ON
Address 09: Cent. Elect. Labels:. 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 N HW: 8P0 907 279 N
Component: Bordnetz-SG H54 2801
Revision: 00H54000 Serial number: 00000008700068
Coding: 11AC2F07A0141380EF00001C4F00000000084E0564010003002000000000
Shop #: WSC 06314 000 08192
VCID: 489FB4A73BD5DCD14B-801C
Subsystem 1 - Part No: 8P2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H10 0040
Coding: 00056595
Shop #: WSC 06314
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 66
Reset counter: 8
Mileage: 144759 km
Time Indication: 0
Date: 2024.01.20
Time: 19:33:00
Freeze Frame:
OFF
Voltage: 12.35 V
OFF
ON
OFF
OFF
OFF
Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533__Gateway H16 0202
Revision: H16 Serial number: 2700K087150898
Coding: ED801F061002020101
Shop #: WSC 06314 000 00000
VCID: 3561CD535C27513920-8060
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 47
Reset counter: 8
Mileage: 144759 km
Time Indication: 0
Date: 2024.01.20
Time: 19:33:19
00470 - Company Comfort Databus in Single Wire
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 3
Fault Frequency: 30
Reset counter: 48
Mileage: 144952 km
Time Indication: 0
Date: 2024.02.03
Time: 17:26:05
Address 42: Door Elect, Driver
Cannot be reached
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 J
Component: KSG H11 0080
Coding: 1980200002186D2D8505489AC637
VCID: 4385A38B02F3FF899E-8016
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Subsystem 3 - Part No: 8P0 951 177
Component: Innenraumueberw.H04 0020
1 Fault Found:
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
Component: Tuer-SG H03 0060
Coding: 0000564
VCID: 4487A09707FDF8B1A7-8010
3 Faults Found:
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
008 - Implausible Signal - Intermittent
00944 - Heated Exterior Mirror; Passenger Side (Z5)
012 - Electrical Fault in Circuit
Took the door card back off and made sure the connectors were seated properly. Now only the drivers window works from the door switch. Both the mirrors and passenger side are not responding to presses on the switch controls, they worked prior to swapping the loom. Also the passenger side switch can control the passenger side window up and down.
I need to look for one of those circuit testers I've got stored away some where to try and check the fuses.
Any other suggestions?
have you used vcds to operate window? is the loom the same p/n or an equivalent supersession that matches your vin. unless i'm daft seems to me if vcds operates the window then the loom/control module/wire runs are intact. if not then the loom is the problem. the control module should be working as the wiring to the mirrors as both worked before i.e. above post
Reactions: dk1234
Cheers for the reply. I haven't used the VCDS to operate the windows. I didn't know that you could do that. I use the VCDS really for doing scans and deleting the fault codes. I haven't ventured into coding etc. Do I just need to go into a certain module, to wind the windows up/down with the VCDS?
I used the part number on the original loom to order the current loom. It has the part number on the loom sticker in a slightly different place than the original sticker, but I assume it's the same part.
Yeah, previously the mirrors and the passenger side window could be controlled from the drivers control switch. After I replaced the loom on Saturday, none were working from the drivers control switch, yesterday after replacing the wires, then just the drivers window is being operated by the drivers control switch. The passenger window, can be worked by the passenger side window control switch.
Also, one other thing on the Digital Instrument Display (DIS, I think is the name) behind the steering wheel, it shows that my drivers door is open and remains like that.
I picked up a cheap multimeter as it was the only one they had left in Halfords I popped into yesterday. I wanted to check the fuses by the steering wheel, by doing a continuity test, unfortunately it doesn't have the "beep" function on a complete fuse some of the better multimeters have. I was wondering, does it matter what side you put the positive/negative probes on the fuse?
On Continuity test I know "1" means there is no circuit / likely fuse is blown. I went through all the fuses by the door, a couple came up with 0.00 and I was wondering if that meant anything, a few I swapped the probes around and then got another reading. I'm new to this, but I think any reading other than 0 is fine?
Someone suggested to check the 12 volts are running through the red/green and brown cables with a multimeter. However, there isn't any space to check whilst the loom is plugged into the door connector as the space is too tight. Not sure if there's some sort of adapter to get into tight spots.
In the meantime I bought a replacement window motor hoping that, that might resolve the issues that I'm having. I've replaced the window motor today and the issues are still the same. Are there any trouble shooting steps you would suggest or to check with the wiring loom.
Maybe I could check the socket that the loom plugs into? If so, how would I go about that.
I messaged the ebay seller to ask if they tested the loom beforehand, this was their response
"Yes this was definitely working when we removed it off the car hence we listed it for sale. And we removed this with great care as I know how fragile these are.
90% of these we remove are damaged hence it was on eBay for less than 3 hours and it sold. So it was definitely working when we removed it."
I haven't done much since the last post. I was going to remove the loom but then thought I haven't done a VCDS scan on the car since installing the new loom. Anyone know where I could get needle probes for a multimeter on the high street?
Are there any companies or people who repair the wiring looms? as my old one is out of the car and has 4 broken wires if I recall correctly. Are there certain repair wires needed? I wouldn't mind paying someone to sort out the wires.
Another note I was previously, before this issue getting an error with the door lock module for the drivers door, where the drivers door wouldn't lock with the central locking, but that I could lock with the key. Anyhow, here's a scan I took today. I remove certain parts as I'm not sure if the whole data is safe to share vin / vcid?
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Cannot be reached 1100
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AP HW: 1K0 907 379 AP
Component: ESP MK60EC1 H45 0107
Revision: 00H45001
Coding: 16426012492400FB680C06EB921B00813900
Shop #: WSC 46093 001 1048576
1 Fault Found:
01169 - Door Contact Switch Driver Side (F2)
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 36
Reset counter: 39
Mileage: 144962 km
Time Indication: 0
Date: 2024.02.05
Time: 08:35:32
Freeze Frame:
Count: 0
Count: 32768
Count: 12800
Count: 147
Count: 52270
Count: 0
Count: 0
Count: 0
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 BG HW: 8P0 820 043 BG
Component: KlimavollautomatH09 0100
Revision: 000397 Serial number:
Shop #: WSC 00000 000 00000
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 11
Reset counter: 35
Mileage: 144789 km
Time Indication: 0
Date: 2024.01.23
Time: 17:09:14
Freeze Frame:
ON
Coding: 00056595
Shop #: WSC 06314
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 224
Reset counter: 39
Mileage: 144960 km
Time Indication: 0
Date: 2024.02.04
Time: 20:57:00
Freeze Frame:
ON
Voltage: 12.20 V
OFF
ON
OFF
OFF
OFF
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 193
Reset counter: 39
Mileage: 144960 km
Time Indication: 0
Date: 2024.02.04
Time: 20:59:20
Freeze Frame:
Fault Priority: 3
Fault Frequency: 142
Reset counter: 79
Mileage: 144960 km
Time Indication: 0
Date: 2024.02.04
Time: 21:08:53
01336 - Company Data Bus for Comfort System
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 1
Fault Frequency: 3
Reset counter: 79
Mileage: 145076 km
Time Indication: 0
Date: 2024.02.12
Time: 15:34:44
Cannot be reached
1 Fault Found:
Coding: 0000564
4 Faults Found:
01553 - Motor for Central Locking; Passenger Door (V57); Lock
012 - Electrical Fault in Circuit - Intermittent
