Good evening!
After several failed attempts I finally replaced the standard front engine mount with an RS4 one.
The first stumbling block I hit numerous times was the six torx bolts that hold the two bumper parts bits that join the bumper bar and bumper to the car. They are done up tight, are corroded and the torx bits I used were chrome vadium steel and they kept snapping. I got around this by buying a steel bit that came attached to a large socket, I WD40'd the bolts and the backside of them too, cleaned out the middle of the bolts from rust and then shocked the bolts with the bit, an extension and hammer.
The next stumbling block I had was that the RS4 mount is a lot harder rubber and the hole was round but what it plugs on to was oval! I could have warmed the part up in some hot water, but instead I cut a few small slits on opposite sides of the hole, which allowed the rubber to expand enough to get over the oval mount. It's a shame I had to cut the mount, a part of me knows it will cause wear quicker, but the first one lasted 140k miles so this stronger one should last a lot of time too.
I ran out of time today so I'll test drive it tomorrow and see it it makes much difference. Here's hoping!
