1.8t with idle problems
Neil Greene Oct 16, 2018
  1. Neil Greene
    Neil Greene New Member
    Hello, I'm new to the forum and would appreciate some help. I have an 03 A4 18t with idle problems. When the engine reaches running temp, the rpm gradually increase to between 1800-2000 rpm. I have to blip the throttle, and after a few seconds, the revs will drop to around 900rpm, but soon after, the revs will start to build up again. This process will continue to repeat itself. The engine has been fitted with a new throttle body but no change to it's characteristics. I am also getting vacuum when I open the oil filler cap. Thinking this a breather problem, I changed the pcv valve. The engine is also pinking under acceleration. Before I commit to spending more money, does any one recognise any of these symptoms. Any help would be greatly appreciated.
    Thanks in advance.
  2. Avatar
    Google AdSense Advertisement
  3. QuattroCalum
    QuattroCalum Well-Known Member saloon Audi A4 Black Edition Saloon Manual
    1,925
    692
  4. QuattroCalum
    1,925
    692
    Have a look at the injector seats, these can crack and draw air in as well as leaking boost. You will undoubtedly see staining around the injectors, use some brake cleaner or similar then blast them with compressed air, then you will be able to see their condition better.
    It could also be perished O rings on the lower injectors.
