Yes, I'm aware of the BEX doubble IC.BEX has two side mount intercoolers,
you could get one from a breaker and the associated pipework.
It's all bolt on stuff.
Well BFB has one, so two would be an improvement. BEX is capable of decent hp power before intercooler upgrade is needed.Yes, I'm aware of the BEX doubble IC.
I was thinking some IC with better flow then the Original IC.
yes, I'm aware of that.Well BFB has one, so two would be an improvement.
Good idea !I got two oem side mounts in the shed from my B7 2.0 TFSI there capable of up to 300-320hp easily.
Not sure on that one, if the 1.8t’s have side mounts then I'm sure you could make something work, theres always a way if your willing to try hard enough, you may need to get the pipework from the 2.0tfsi and make a Frankenstein out of the two.yes, I'm aware of that.
Good idea !
But do they fit the hoses/piping of the 1.8T ?
This is the exploded view from ETKANot sure on that one, if the 1.8T’s have side mounts then I'm sure you could make something work,
you may need to get the pipework from the 2.0 TFSI and make a Frankenstein out of the two.
