Hi, I have a idle issue very occasionally i get a slight shudder, on Block 32 my adaption idle is 5% the engine is running rich also having random misfires on all cylinders mainly cylinder 3. I have smoke tested the engine and found nothing New coils, haven't done sparks yet they are quite black. None of the vacuum lines look damaged, the PCV system seems to be working fine. Its driving me insane, has anyone had similar?
There are so many things that can go wrong on the 1.8t engine. Mostly pcv system. First check the crankcase breather pipe that exits the block below the inlet manifold, famous for breaking. Then I would check the pcv one way valve, that can upset fuelling although it is usually accompanied by high idle speed but not always. Sent from my ANE-LX1 using Tapatalk
Have checked and replaced all of that, don't seem to have any issues but thinking about cleaning the metal pipe after the engine block, recently been playing with the fuel pump plug that made a difference to the performance and the vibrate seemed to go away but has come back so still go some playing around to do.
