Hi. Is there any guide or DIY about how to remove crankcase on this engine? The only info i found is about AUM and newer engines. If it's possible to be without installing a catch can.
Thank you very much. Another question not about crankcase ventilation. With this air intake (cone filter) do you have the intake sound a.k.a turbo flutter with stock dv?
I saw many 1.8t with flutter sound but with aftermarket bov. Also im seeing them reving the engine on idle and blow off sound is there. I know that 1.8T is not making bost pressure on idle. So how is this possible?
If you want to run a blow off valve you would need a piggyback or aftermarket ecu. I will be running one which will allow my car to have a mafless tune. There is no way I'll run a blow off valve on an Audi though!
