06 A3 1.9tdi Sportback Drivers Door Switchs No Power
Ady786
Hi i have a problem with my drivers door switchs none of them work lock unlock button dont work window switch dont function like thers no power door locks and unlocks fine with key speaker works just the switchs aint working all of the other door switchs work fine just drivers door has the problem
Geah
this will probably be a broken wire / wires in the door loom mate its very common
open the door as far as you can
pull the rubber boot back that goes from door too body its inbetween the door hinges when the doors wide open
find the broken wires and
strip them back soilder them up insulation tape / heat shrink them check everything works pull the rubber case back and enjoy
andyz
As above, I have the same issue with no sounds from the drivers door speaker!
If its a right mess there are some harnesses on the bay at the moment but you'd need the part number from yours to be sure you're buying the right one.
Ady786
Hi thanks for your help guys it turned out to be a faulty switch
