So drive home from work Thursday evening, car suddenly developed an exhaust blowing, so carried on to home, opened the bonnet ans could see bolts at exhaust to Cat loose and one missing. Put my arm right down from engine bay to confirm, cut up my are alot.
So called my Audi mechanic who`s garage fitted it and me up with him today even though he was closed he had a look.
I told him there are not any nuts fitted on the bolts? but on inspection he says there is no way you can fit bolts and nuts as the bolt will not fit, as the the Cat pipe is bigger an closer to the mounting hole so the head of the bolt will not sit flat.
The guy who works with him fitted the three bolts from the exhaust flange to the cat threaded flange, this means the bolts will become loose and fall out.
Our solution is to fit the studs to the exhaust flange, connect the exhaust flange and fit nuts. this will work but studs need to be really tight of tack welded to secure.
I will go back after Easter to take it all off again, he just tightend the bolts for no to keep me going.
What I dont get is the fitting kit had three bolts and nuts yet the holes for the bolt are to close to the pipe,
so how was it going to fit??
