  2. Dismiss Notice
01435 fault
Conza Jan 8, 2015
  1. Conza
    Conza South East
    121
    20
    Hello all :)
    Right just getting to the bottom of fixing my Audi A3 that I brought from copart with accident damage
    It's coming up with "esp fault see owners Manuel" in the centre display
    So I stuck the vcds on it at work and it came up wit
    01435 - brake pressure sensor 1 (g201)
    012 - electrical fault in circuit
    I haven't had chance to look if the abs pump was damaged in the accident but I wouldn't of through so looking at the damage
    On the Ross tech website it says try going into basic settings on which I tried but I select the pressure sensor and just get error in the box :-/
    but heres the odd things
    -on the way home from collecting it 2 of the brake lights wernt working and they now are.
    -and while i had the vcds plugged in a pressed the brakes and it came up with a brake warning in the centre display
    so ross tech also say it could be brake light switch which above faults could say it could be that,
    so it is worth trying a brake light switch as i dont have a lot of money to spend at the mo but have anyone else had same faults
    heres the cars current state just waiting for my bumper and bonnet to be painted
  2. Avatar
    snack-media
    Advertisement
  3. Dave-S3
    Dave-S3 Registered User
    653
    124
    43
    Needs a new abs unit or the repair kit google it its a super common fault the repair kit is about £200 iirc.
    irowpod likes this.
  4. Conza
    Conza South East
    121
    20
    i dont think that :( i hoped it could of been a cheap brake light switch
  5. Dave-S3
    653
    124
    43
    nope sorry, as i said google it its very common 01435 G201, had it on my golf and left in the end, your lucky the fix used to be a whole new abs unit at at least £500 fitted!!
  6. Conza
    Conza South East
    121
    20
    whats better to do do the above fix of send unit to someone like bba-reman that give a lifetime warranty
  7. S3 AEX
    S3 AEX Registered User
    751
    212
    43
    Try breakers yard for a abs unit, I got one for my old golf £99 plus postage.
  8. irowpod
    irowpod Registered User
    82
    10
    Have the same issues with my front impact a3. Will be going down the repair kit route. Fixed my golf 5 with similar issues but this was not accident damaged.
  9. pluves1
    pluves1 Registered User
    725
    133
    43
    What other damage was caused in the engine bay? Judging by the pictures I would have guessed that the bonnet was pushed back onto the top of the engine at the very least.
    Why not try swapping out the brake pedal switch if the part is not too expensive?
    Judging by the Ross-Tech info I'd be checking the following in this order
    Perform Brake Pump Bleeding
    Perform Brake Pressure Sensor 1 (G201) Basic Setting
    Check/Replace Brake Pedal Switch (F)
    Check/Replace Brake Pressure Sensor 1 (G201)
    ABS Hydraulic Unit (N55) may need to be replaced
    Replace/Check Brake Electronics Control Module (J104)
  10. Conza
    Conza South East
    121
    20
    There was no damage to engine, only broke what I've replaced and the airbox took a bit of it but collected most of the bits for that and plastic welded it back together for the mo,
    I think I mite try a brake light switch tomorrow
    I tried basic setting with no success but just get errors come up so think it is the pump itself
    I know the repair kit is cheaper bit have they modified it so u never get the fault again as thinking about spending the extra and sending it to ecu testing or bba reman who give a lifetime warranty
  11. jasonbather
    jasonbather Registered User
    Hi mate had the same problem on my a3 turned out to be a dodgy wire by th brake light switch hope this helps
  12. Avatar
    snack-media
    Advertisement
  13. Conza
    Conza South East
    121
    20
    Is it correct that the brake light switch is on the master cyclinder as I have only done golfs,fabias etc at work and there all by the pedal
  14. irowpod
    82
    10
    Yes from what I have heard its under the brake servo
  15. Conza
    Conza South East
    121
    20
    Are they a pain to do and easy from the top or bottom ?
  16. irowpod
    82
    10
    Bottom it is
  17. Conza
    Conza South East
    121
    20
    I see it now that looks a laugh to get to lol
    irowpod likes this.
  18. aaronlouiswhite
    aaronlouiswhite Registered User
    Seems very light damage to end up at Copart in the first place for an A3 at that age...?
    Looks like all just bolt on parts? Wouldn't that suggest there may be something more with the abs than a brake switch?
    Good luck with it anyway
  19. irowpod
    82
    10
    Damage level doesn't really come into it. Costs or repair determine what category level it is. Secondly any car that had had airbags deployed and any kind of suspension damage normally ends up on Copart as a cat C.
    If a basic reset fails , next on the hitlist would the sensor changes and the abs repair kit . I am having mine looked at Tuesday with the same issue , I will feedback results .
  20. Conza
    Conza South East
    121
    20
    I think they cat d it because it took the rad with it, and that will be very grateful for your finding
    And I have had it on the road for 2 days now and it's drives and brakes lovely just has no abs/traction control/esp but I'm used to that anyway with my nova :)
  21. irowpod
    82
    10
    Right feedback is I have had to change the steering angle sensor, and the abs kit replaced. One of one rear abs sensors was throwing a mechanical fault , have had this changed along with a wheel bearing.
  22. Conza
    Conza South East
    121
    20
    Ok I'm just getting the pressure fault but I've borought and paid for the brake light switch now so mite aswell fit it
    irowpod likes this.
  23. irowpod
    82
    10
    If you havent fitted it by tomorrow. Will get you the how to tomorrow. Cheers
  24. Conza
    Conza South East
    121
    20
    That will be very helpfull, had one go but the bolt seams almost impossible to get any kind of tool on lol
  25. irowpod
    82
    10
    I have the information you need. A brake pressure switch which is different from a brake light switch.
    The brake sensor switch comes in with theABS repair kit from the dealers. If they cannot repair under good will or warranty . TPS sells this for £152.57.
    In my case I also required a steering angle sensor at £72.31 .
    My rear near side Abs sensor was throwing these fault codes or relaying to the ABS pump that it was skidding .
    It has come at a cost to me , in hindsight I will do it myself.
    You will of course need to re bleed your brakes and require a one man bleed kit. Brake fluid and loads of time in your hands.
    However it will save you at least £250 on labour alone.
  26. Conza
    Conza South East
    121
    20
    I'm am a mechanic so will be doing it myself, is the £152.57 including vat
    We have a electric pressure bleeder that screws to the master cylinder so sorted there.
    I've already borought and payed for the brake light switch so gonna fit just wanted some tips and pointers on how to change the brake light switch, is the abs pump easy to get to when u remove all the battery etc
  27. irowpod
    82
    10
    It Excludes vat. yes abs pump is easy to replace. You don't need to remover the whole pump. The abs kit is the front black bit of the pump and not the whole pump. Just your Allen keys and the brake pipe spanner of course.
  28. Conza
    Conza South East
    121
    20
    Cool :)
    I will be doing mine in a few weeks just desiding what's needs doing 1st the clutch/flywheel or abs pump lol
