I'd think that you'd find that a quick application of a big screwdriver will have the broken one out quickly and will destroy the still, if it is still, intact but corroded one, these Mikolar clamps are way over the top for that job, still better to be "over the top" than cause you grief in a few years time, I'd think that the same type as VW Group use but cheaper versions would see you okay for maybe another 8 years.
Edit:- one thing, in case you have not thought of this, or in my case had to deal, this time with both clamps broken is, the plan should be to have the bolts vertical at one side, the bolt head end downwards - I only had a few minutes to sort out my older daughter's Ibiza and I just fitted the clamps with the bolts pointing downwards as the original type of clamps retain the head of the bolts, ie stop them turning - so the quick and easy way is to fit them with the nut end downwards which leaves a long length of bolt sticking downwards, not clever or a good look - but she traded it so not now my problem!
Most of that was probably irrelevant as Mikolar designed these clamps a bit better!!
Edit:- one other maybe mamby pamby comment is, these new clamps as they arrived, will bot have a hole in them to correctly position them on the joining sleeve, the original design of clamps have a depression on them to accommodate the clamp in the correct position - I'm just altering you to that, that is all.
