Android Torque / Bluetooth Connector
Ian W
Wirral, Merseyside
Just been reading about Android Torque and sounds like a handy tool.
Can anyone confirm that it will read and clear fault codes on the S3?
Do I need any specific ODB2 BT connector or will anyone from Amazon do the job?
Thanks :redrs4:
it connects to the elm 327 dongles, if your car is a facelift model it should work
I have one of them and the app torque pro I think it's called and it will read codes and clear them. It's also got a lot of gauges you can set up. I dont use mine now that I have the colour mfa as it does it aswell. It was good when I did use it.
If you haven't bought one yet if you can wait until I collect my car from badger 5 its in my glove box you can have it. I'll post it to you.
Thank you, I appreciate the offer though I bought one on my lunch break via Amazon Prime as I have a fault code I want to read.
Frustratingly, I gave away my ODB2 cable when I sold my last S3!
Can report that this worked a treat.
Fault codes as expected, the fact that the CAT is sat in my garden is the issue :whistle2:
Reactions: hydro s3
