Retrofitting dynamic tail lights to PFL SB-ADVICE NEEDED
s3facelift09
Croatia
I'm in a search of dynamic tails for my Sportback. I can buy Hella or Magneti Marelli, does anyone know is Hella or Magneti Marelli the OEM producer of the lights?
Since there is a hatch, sedan and Sportback, it's very difficult to find the part numbers of the inner and outer light for the Sportback, I would be much obliged if someone has the part numbers, and also the part numbers of the back covers of the lights that don't fit from the prefacelift lights to the facelift ones?
If anything else is required, please let me know, I will let you know the results when I do the upgrade.
Part numbers are:
M V8V4 945 091 N/STOCK TAIL LI 1.00
M V8V4 945 092 N/STOCK TAIL LI 1.00
M V8V4 945 093 C N/STOCK TAIL LI 1.00
M V8V4 945 094 C N/STOCK TAIL LI 1.00
Crewe Audi on here can supply them for a good price. They will then need coding or modules to make them work. Not sure what you mean about the back covers.
Cheers :)
Reactions: creweaudiparts, s3facelift09 and 8YARWY
Mine when I bought them for the PFL.
Reactions: jimojameso and s3facelift09
Part numbers are:
Cheers :)
This is a quote from a post of a member here on this topic of retrofitting:
Also the FL taillights' plastic trims are different, you can still use the PFL ones but it's not a perfect fit.
Maybe he's thinking of plastic trims that cover the lights openings from inside the boot.
The lad that bought my RS3 has the dynamic lights and Audi retrofit wiring adapters for sale if it’s of interest to anyone?
Yeah the USA aren’t compatible with EU cars.
Found that out the hard way back in 2016
I'm guessing this was heavily discounted?
The prices have inflated quite a bit since that invoice Sean!!
Going back nearly 2 years and the Crewe Audi price was £680 I think
Was for part number reference only.
Yeah I knew.
Just for the ones saying great price
Well it actually was double that
We ordered the USA lights and they were none return
Still have them here too.
Reactions: Marshy
If you search the part numbers on ebay you can get some of them individually to cut down costs. Just make sure they are in good condition. I bought the inner ones off ebay and the outer ones from crewe audi :)
Finally I have some time to post some pics of the successfully retrofitted dynamic tail lights that I did over a month ago.
20201028 174142
20201028 180439
20201028 185157
20201028 190221
20201028 185153
Reactions: RS03???, jimojameso and D0C
