A3 8P to A3 8V
leonwilliams
West Yorkshire
Hi having owned 8p for over 4 years now moved to the 8V 21,000 on clock So far happy just a couple of things on motorway doing 80mph couldn't get it past that on a slight incline on flat it picked up. This has audi drive select still getting round it. My 8P was a beast 140 2.0 TDI it was mapped 50/50 had 100.000 on clock I know I can't compare the 2 but surely this 8V should perform better anyone like to scan for me if there is an issue can go back to Audi. Also sometimes its lazy starting turn key glow plug goes out turn key pause few secs then it starts. Mentioned this to Audi they said it's normal for a diesel to take upto 10 secs to start. Leave that one with you I know how long it should take.
Reactions: Sandra
It wouldn't get above 80mph? Did I read that right?
Reactions: Adam14
Just as well it can't go above 80mph given the 70mph speed limit. Ticket saved
Sent from my HD1913 using Tapatalk
Reactions: leonwilliams and Dubjam
What engine is in it?
should defo get above 80! My works van gets up to 80
yeah the diesels do take a couple of seconds to start when cold, just the glow plugs doing their thing. Think it’s a safety thing. Older diesels just turn the key and let it crank whereas the newer ones are more intelligent and make you wait until sufficiently heated up
150 2.0 TDI my 8p was 50/50 mapped was quick before mapped. Just find throttle response slow
My 150tdi stronic has a bit of go to it, maybe you just expecting too much
Looks like Audi JCT600 York ?
Yeah might be mate just it for a short run up motorway hit 70mph then put foot down throttle pedal went to floor it slowly picked up but foot was to the floor ?
Ok so Audi had car for couple of hours did all test came back with car is fine. I noticed that the mmi was initlising looked like it had a reboot also noticed car was more responsive.
