Dash cam power from overhead panel?
What dashcam are you fitting?
I fitted mine just under the rear view mirror, tuck the wire under the head lining along the screen and down the pillar trim against the screen
and gap between the dash to the fuse box, you need to use plastic trim tools to push the wire in place. Connect to switched live.
Reactions: Charlie Farley
Super easy to piggyback off an ignition live fuse in the fusebox and run it up the A pillar.
