Avant coilovers fitted
Bulldog
Kent
Finally had my KW coilovers fitted yesterday went for KW street comforts & I can honestly say they are an amazing drive. It’s like driving on a magic carpet now.
594CB484 59C2 4C96 AD2A DF687F00DB7F
E2B73D1C FAFB 4A12 A303 DE6AC0C48C29
B9E085DB 76D4 4A44 B01B 38BAFBFF1A41
D8DE24A1 B124 430C BD6D 463C5CCF8A28
Reactions: Moon, gary3306, Radford212 and 6 others
In the pics above I’m running 5mm rear spacers but need to change those to 10mm & I’ve also fitted 12mm spacers on the front. I’ll get pics later after I’ve washed it.
After a good clean I also raised the front 5mm. Now I’ll be on the lookout for a set of 21’s.
EF3BE992 B85F 427B 92F5 2383BCA1E642
77F8BC8A 08CA 4023 8FCF BD52AD735950
47433825 FF26 45F5 9B2D 2BEDCE468C59
Reactions: DaveW and Rhyso
Sweet! thats my mind made up then! what was the overall drop over the S Line setup? and why the spacers? to prevent catching or for aesthetics?
Reactions: Bulldog
Where did you get them exhaust tips from mate? I like them. Seen some on Ebay from Hong Kong but dubious of quality.
It’s lowered about 40mm from standard. The spacers are just to fill the arches out till I get a set of 21’s.
Yeah from EBay & quality & fit is ok for the money.
Reactions: gary3306
How much effort is it to change the ride height? From what I've read you have to jack the car up to adjust? Is it also a wheel off jobbie?
Next question, how did you decide on the damper settings to use?
Sorry for the questions. I've never had coilovers and am thinking of having them fitted.
@rjwojcik when I adjusted mine I did jack it up & remove the wheels but I’ve only done it the once as once it was set I’ve not needed to adjust it. On my KW’s they have a 16 stage damper setting & they recommend setting to 9 but I have been wanting to stiffen them up to 12.
Most budget coilovers come pre set for damping but it depends what ones your looking at.
Reactions: rjwojcik
