My car is a 63 plate 2.0l tdi 150 so likely you will have the horrible thing in there.Your a star, thanks again @Bigjase88
All it does is increase lifespan of coolant, if you remove it you will need more frequent coolant changes.I got a 63 plate 2.0 tdi 184.. I'll check mine tomorrow too!
Would be a 4 figure job. So worth binning the silicone bag right offIts done 119k right now with no problems, but it could be a ticking time bomb
New heater matrix would be so expensive, especially when you probably have to rip out the dash.
Given that cam belts need to be replaced at least 5-yearly intervals, at which point people generally renew the water pump as well (which results in a large part of the coolant being replaced), it seems a rather unnecessary move to have this foreign object in the expansion bottle. Many manufacturers use "lifetime" pink coolant and don't do this.
I agree you seem to have been unlucky - your car sounds a great 2nd hand car on paper
I've checked mine and I have the tag on the tank, but I can't see the bag from looking in the opening.
Hi mate i just took the bag out and topped up coolantYou have to replace the whole tank?
I thought you would be able to just take the bag out?
They don’t split in halfOK I have it in mine as well, but its stuck in some sort of holder on the side and I cannot just lift it out without the possibility of breaking the bag.
I have noticed some clips on the side, but it wont unclip, does the bottle break in half or is it a sealed unit? It looks like it breaks in half
Also how do I know which coolant I have as I have heard some are not compatable therfore cannot mix, its a very neon pink, almost like pepto bismol.
Thanks @Bigjase88
I was hoping I could open it in half and take out the gel pack and refill the tank.
Ah well, another purchase I didnt need LOL
I did not get my car done at Audi so even if I have G12 it will still be ok with G13?
Do I need to clamp the bottom hose to stop liquid going everywhere, or does it not matter if it goes on the engine?
Thanks for your help, never replaced a coolant tank before
Well i guess notI have been looking on a VW forum and they are just taking the tank off and forcibly removing the bag when the tank is off. They are then putting the tank back and putting more coolant in it.
Do I really need to buy a new tank at £30.00 + costs of G13 coolant?
See attached linkSorry to bother, but will this stuff be ok to mix, it looks a little purple on the side window
https://www.ebay.co.uk/itm/GENUINE-...988682?hash=item2d14b5d30a:g:ifAAAOSwX9VfMx~S
Just buy this and stop worrying. Buy 2 evenYeah sorry I know
But wanted to make sure the link I gave is the stuff I need?
Some stuff on amazon want £40.00 which is a joke, but this is a tenner and says VAG OEM
