Quattro System on A6
Roberto71
Dublin
Hi all,
Quick question to see if someone here can confirm. Does the A6 have a different Quattro system on the A6 depending on the engine or is that just in the US? I've read comments on youtube and elsewhere that the 45 TSFI engine with the DSG has Quattro "Ultra" which is the glorified Haldex system it seems, and the higher Torque engines like the 50 TDI have the regular full fat Torsen permanent system.
I know Audi were planning to bring Ultra to all longitudinal engines but that the 6cyl diesels were too Torquey for the S Tronic box and because they need the TipTronic they have to use the Torsen system.
It's hard to find the answer to this. Audi clearly wants to introduce this system to all cars as they say it can reduce fuel consumption by 0.3 litres per 100kms and in the new WLTP era that can mean a lot. But I'd hate to see the full fat Quattro gone with it's rear-wheel bias gone.
As far as I know over here in the UK we have just the one flavour of Quattro.
I do know my 45 TFSI Quattro with 7-speed S-Tronic box outputs the power as 30% front/70% rear axles as default mode so you can call this a rear axle bias?
To start with Audi did only have a single quattro system but they introduced the haldex version for the A3 8L 20+ years ago and then used it cars like the TT & Q3. Bigger cars A6, A8 etc have always been torsion (mechanical)
Standard quattro cars are only ever 50/50 split you have to go to the high end RS cars to get rear wheel bias.
Are you sure. This https://www.audi.co.uk/audi-innovat...MIqLKey4DD6gIVV-DtCh1o7Qs1EAAYASAAEgKnKPD_BwE would suggest that only the RS6 has the rear biased version of the centre diff
I must have picked it up on an article similar to this, and I was incorrect with the figures of 70/30 above as it says it is distributed 60/40 here:
https://www.carbuyer.co.uk/tips-and-advice/170257/audi-quattro-all-wheel-drive-explained
"The system fitted the A4, A6 and Q8 is most common, and here the quattro system has a default engine power split that’s biased 60% to the rear wheels and 40% to the front wheels. It’s designed to give the driving feel of a rear-wheel drive car in normal use, but if the rear-wheels begin to lose traction the system can instantaneously divert more power to the front wheels."
Although that is only a marginal bias and I doubt it would even be noticeable. Certainly won't kick the rear end out if you put the throttle down too much.
Thomas from Autogefuehl seems to confirm it here. The TFSI's have the the Ultra system.
