Hi guys,
I've got a 8P 2011 A3 Sportback and it seems I'm one of many unlucky Audi owners as the hinges on the left side of my glove box have completely broken off. What I want to know is, before I spend £150+ on a new one, is it possible to repair it with the hinge repair kit? The pictures below show the broken hinges, and the light only turns on when you pull the hinge out manually. The right side seems to be fine.
And if I do replace the glove box, will I also need to recode the airbag or AMI with with VCDS as I'll need to disconnect the cables? Thanks.
https://imgur.com/gallery/kPKssbg
