TTE500+ Upgrade Performance Turbocharger 2.5 TFSI TTRS 8J / RS3 8P/8V.1 / RSQ3 /RS3 8V
Shaun's TTRS TTE500 MRC Tuning software
564PS 713Nm
Mods List:
TTE500 Turbocharger
MRC Stage 3 Tune
MRC DSG Tune
Evolution Custom Downpipe Ceramic Coated (inside and out)
Audi Performance Exhaust
Forge Intercooler (Nano Ceramic Coated outer only)
034 Motorsport Intake
Autotech HPFP
Coolboost Stage 2 WMI(not tuned for, only used for cooling and to ensure fueling is safe)
NGK 7438-8 Spark Plugs
Upgraded Prop Bolts
Two weeks ago Shaun ran at a local track, Killarney which we are told has no grip at all. Street tyres and with a not so great 60ft time still managed 11.385 @197.7kmh with a head wind and 10deg weather.
Shaun hopes will get this down to 11.0 on street tyres before he goes to slicks.
Makes 25th on the owners times board
https://www.theturboengineers.com/100-200-1-4-times
#TTEPOWER #MRC #TTE500
What air filters are everyone changing too from the standard 034 intake?
Hi could you tell me how much power you can safely put through an RSQ3 before having to modify the engine internals? Also if i was to purchase one of your turbos do you provide all the settings for my local performance garage to map it correctly or do i have to take it to someone like MRC?
500+ Is quite safe. I feel upto 600 out there stock motors.
We only supply the turbochargers. Calibration of the ecu software is handled by the tuner. MRC is recommended.
Reactions: M3eater
Stage 3 Evo Engineering
Audi TTRS 2.5 Tfsi
- TTE500 Turbo Upgrade
- full Miltek Race exhaust
- Upgrade HPFP
- Wagner Evo 3 Intercooler
- Dv+
- intake VW Racing
- kit clutch Sachs Racing
- custom mapping JE Engineering
- 98 Ron
509Hp 716 Nm
Something special.
Golf 6R TTE500 2.5TFSI DQ500
521PS 689Nm (no wmi)
#TTEPOWER #TTE500 #WAGNER #THTPERFORMANCE
Two RS3 TTE500 results
RS3 8V TTE500 By KSF Motorsport using MRC Tuning software
537PS 737Nm
RS3 8V By MTR Performance
513PS 761Nm
NEW 1/4 MILE TIME ADDED TO TTE OWNERS BOARD.
No 19
11.003 sec at 124.79MPH
RS3 8V TTE500
Decat DP (stock exhaust)
Wagner IC
HPFP upgrade
Eventuri intake
Aem wmi
Pump E85
Full weight 1590kgs Plus driver
Street tyres Michelin pilot sport 4
ETUNER ECU & DSG software
Driver : Trent Demos
RS3 8P 2.5TFSI 360, TTE500 Turbo backed up by a Wagner intercooler, Milltek exhaust and sports cat, intake and uprated HPFP.
MoreBHP custom Stage 3 tuning takes it to 515bhp
#morebhp #tte500 #wagnertuninguk #vrt
RS3 8P
Race Developments engine, TTE500 turbo, full custom exhaust, Forge FMIC, Large intake pipe, HPFP upgrade
MRC software
545ps 783nm at 1.9 bar
99RON (no wmi)
RS3 8P TTE500 Turbocharged making 539ps 736nm using MRC Tuning Custom ECU software 99ron (no wmi)
#TTE500 #TTEPOWER #MRCTUNING #RS3
Audi RS3 2.5 TFSI 367pk Quattro DSG7
ORG/OEM: 367pk & 465Nm
JD Stage 3: 554pk & 683Nm
Specs:
TTE500 Turbo
Upgrade HFHP
Milltek downpipe
K&N intake filer
JDE Stage 3 software
JDE DSG Remap
RON100 fuel
Congrats to Dmytro Koposov in his RS3 8P TTE500 with REVO Stage 3 ecu software and sprintech DGS software making a 10,sec 1/4 mile pass at Odessa Super Cars Run 2018 in Russia.
10.8Sec @120mph Full weight is claimed and 102 fuel used at the event.
The next day, on 98 gasoline Temperature +22. Urban asphalt. Racelogic Pbox: 0-100: 2.86, 100-200: 7.6, 0-200: 10.5, 1/8 6.9 165 km / h, 60 feet: 1.6, 1/4 (402 m): 10.8 202.4 km / h
#TTEPOWER #TTE500 #10SEC #HYBRID
Reactions: Barba
RS3 8P TTE500 REVO SOFTWARE TESTING
98RON WMI
Audi RS3 2.5 TFSI by Evo Enginee Ring
OEM Specs: 344HP & 450Nm
JD Stage 3: 529HP & 703Nm (with RON98 fuel)
JD Stage 3: 552HP & 710Nm (with RON100 fuel)
Specs:
TTE 500+ 9blade turbine
Full Milltek exhaust
Wagner intercooler
034 intake
LOBA HPFP
GFB DV+
JD Stage 3 software
JD Stage 2 DSG software
FAST SUV...
Audi RS Q3 TTE500 (9 Blade)
MTR PERFORMANCE SOFTWARE
555PS 692Nm 102ron
#TTEPOWER #TTE500 #MTR
Дмитрий Копосов RS3 8P TTE500+ REVO Stage 3 software
1/4 MILE 10.72sec
100-200Kmh 6.76 Sec
TESTING ON DRAGY
#TTEPOWER #TTE500
Audi RS3 8V MK1
Stock: 367.0 HP / 465.0 Nm
DVX 546.1 HP / 703.0 Nm
Custom DVX performance Belgium Engine Remap
98ron fuel 10% E
✅ 179.1 HP↗
✅ 238 Nm↗
DVX Stage 3:
- TTE500+ Turbocharger & inlet
- Air intake
- Milltek Turboback exhaust
- Upgrade HPFP
Turbo info : https://tteglobal.com/…/8v.…/28/tte500-upgrade-turbocharger…
#TTE500 #TTEPOWER #DVX #Worknotblabla
Reactions: M3eater
Eero Kallioniemi in his TTRS TTE500+ (9blade)
546HP 704Nm (mustang dyno) Stertman tuned
100-200 6.68
1/4mile 10.73
Audi RS3 8V 2.5TFSI - Etuners Stage3 for TTE500+ 98RON
Turns out the new and upgraded TTE500 turbocharger was really worth the wait. Even on 98RON it produces solid performance, even in unfavourable environmental conditions. (copied from etuners)
- Upgraded turbo: TheTurboEngineers TTE500+
- Upgraded Downpipe
- Upgraded Intercooler: Wagner Tuning
- Upgraded Intake Kit
- 98RON fuel
- #Etuners Stage3 ECU remap
- #Etuners Stage3 DQ500 gearbox remap
- Performance Results: 447whp - 443wtq .
Audi RS3 2.5 TFSI
Original: 367pk & 465Nm
Vagtechniek Stage 3 Chiptuning: 541HP & 683Nm
Modifications:
- Vagtechniek Stage 3 Software
- Vagtechniek Stage 2 S-tronic software
- TheTurboEngineers TTE 500+ turbocharger
- upgrade HPFP
- Wagner Tuning EVO 3 IC
- OEM sports exhaust (DECAT)
- OEM airbox
- RON 102
Albeto's TTRS TTE500+
REVLIMIT Software
556hp 720Nm
RS3 8V TTE500+ by WERK2
Custom tuned. 535PS 691nm
Interesting comparison shared by DVX performance Belgium
The same RS3 8V PFL with the same mods, 98 fuel, dyno only change is Swapped from the old TTE500 hybrid with the K24.2 turbine to Newer version TTE500+ with the TTE9blade exhaust turbine. (software adjusted to suit each time)
Mods
CTS Intake
Full exhaust
HPFP
Result:- Performance increased
More peak horsepower & Torque has a bigger peak & holding, so more area under the curve & it's all sooner.
Audi RS3 8P 2.5 TFSI 521HP by BR-Performance Nederland
Stock : 340 Hp / 450 Nm
TTE500+ Stage 3 : 521 Hp / 680 Nm (limited for stock engine!)
Dragy 100/200 time tested = 7.93s (2 people)
Multimap added @ Bosch MED9.1 ECU!!
--> Map 1: Low boost = 455 Hp / 600 Nm
--> Map 2: High boost = 521 Hp / 680 Nm
98RON Fuel
- TheTurboEngineers TTE500+ turbo
- HPFP upgrade
- 034Motorsport Carbon air intake
- Milltek Sport Full turbo back exhaust system
- Wagner Evo 1 Intercooler
- BR-Performance Nederland Stage 3 remap + DQ500
John’s RS3 PFL TTE500+
034 intake
Decat DP - Stock catback exhaust
Hpfp
FORGE intercooler
TTE500+ Turbo & inlet
@bevo tuning software
99 Ron vs 99ron & meth
507hp 470ftbls
541HP 540ftbls
Spool-up is nice & early and torque is nice smooth on this set up
Turbo info RUNTTE.COM
#BEVO #TTE500+ #RUNTTE
Vjeko Dora's TTRS 8J TTE500+ vs 991 TURBO S
REVO Stage 3 ECU software and TVS tcu @1.5bar boost 1/4mile 10.89sec
Loving how this turned out!
TTE500+ & TTE CNC Inlet for the RS3 PFL With our latest TTE Thermal isolation shielding available as an extra.
This specially ordered unit is for Evo Enginee Ring
TTEGLOBAL.COM
