Car is up on blocks
Silly boy here whacked my front driver's side wheel off a kerb moving sideways, don't ask
Noticed when I turn the wheel all the way when doing a u-turn etc the driver's side makes a noise before straightening backup. Nearly sure there is also a squeak, and a slight wobble when driving I think.
To my horror after a long spin noticed the wheel has a 'negative camber', that is the bottom of the wheel is further in that the top, and the whole wheel seems to be out further than the wheel arch by about a 1/4 or 1/2 inch. There is also a small outwards dent on the top of the arch and a crack in the paint. When I saw all this it dawned on me the wheel probably wobbles in the arch as I'm driving.
So now I have it up on blocks and can't tell what part might be bent or needing replacing. It all looks fine and the same as the other side minus the axle which is obviously different on both sides. Any of you experts able to see anything wrong from the pics or know what might be the problem?
