that warranty though.....Or just sell it all and get a Kia, errr maybe not, well not a Kia that is.
Fuel pump control module location, No way water got in there.
Sent from my TA-1004 using Tapatalk
Remove the fuel pump, it will be easier, there is a metal plate. I have never removed it so these are the instructions from my mechanic.so how does it come out then chap, no way its coming out of that small gap where the wire comes out.
i think this is true only in saloon, in avant its behind rear seat under all the rear trim-the spare wheel liner has to come out
I think this is only true for FWD cars.i think this is true only in saloon, in avant its behind rear seat under all the rear trim-the spare wheel liner has to come out
Sent from my ONEPLUS A6013 using Tapatalk
I don't know either but I haven't heard of it being body specific. We have different fuel tanks in 2wd and 4wd and that's why I believe the tanks are in slightly different places.I wasnt sure if the difference was in the body or drive train to be fair
There's a possibility of that but the prv is a dumb valve meaning it just opens when it reaches its designed fuel pressure and otherwise its closed. I'm not sure what would cause it to go bad or what symptoms it would show if it did.Random thought, would a failing PRV have any impact, my thinking it leaking rail pressure
You did replace the LPFP?I've been on this problem all afternoon and it has me stumped.
It is most certainly getting more frequent , and it wont clear at all now.
The same old fault codes aswell.
I have disconnected every sensor that's being flagged as open circuit etc and all except one do respond in vcds as being unplugged etc .
The n276 doesn't make any difference , same message , open circuit and that's with another HPFP and there is no difference weather its plugged in or not with the exception that I can clear the other 3 faults no problem , but with the engine running the n276 fault wont clear , it just make the car run even worse when trying to clear the error.
the scan shows it's getting enough voltage .
what I have now noticed is that the fuel rail pressure requested is 50 but acctaul is 7 and when cranking the hpfp goes to 100.
I've eliminated all the 4 faulty parts as not being faulty , wiring test don't show anything abnormal but I also fitted a new lpfp .
I'm thinking it may not working properly based on the low fuel rail pressure and poor starting again.
would this sound like a possible source still even though its a new pump assembly.
You just need to look at duty cycle for the pump at idle to know if it's going bad. I wouldn't buy that without looking at that first.very tempted to just buy a brand new LPFP , not an ideal situation just throwing more cash at the problem but can't see what else to do at this point.
Not as yet, wouldn't it throw up a code aswell.Did you change the rail sensor? Also known as the thrust sensor? It's behind the alternator under the intake manifold.
It would. I was asking because if you had then you had to make sure to get the correct one for the VIN split. Depending on your VIN depends on the part number.Not as yet, wouldn't it throw up a code aswell.
I think it's 103 or 106. You could just monitor both. I'll have a quick Google look.just refresh my memory Edgar, which block number is that.
I know you just ran that duty cycle test but I forgot to mention that the engine temp needs to warm at idle. Else you'll get a high idle and high duty cycle reading.Ok Edgar,
just had another go and it just wont have it, EPC is just stuck on.
did a quick scan.
can clear 3 of 4 faults but the n276 wont go, here is the log plus two of the real time pressures.
View attachment 202403 View attachment 202404 View attachment 202407
The code points to the HPFP, particularly the N276 on top (I know you know this already). Do you have a spare pump to swap in? I thought you did that recently with a spare someone sent you? Your LPFP duty cycle is extremely high. If the LPFP is good then you're risking damaging it by running it at such a high duty cycle often. Keep in mind that if other fuel components are failing they may be making the LPFP work extra hard to supply the demand.Yes , warm engine.
I still cant get my head round the open circuit problem.
I don't have the post up on my phone but it was mentioned in a different post that at least 3 of those sensors share the same fuse. Maybe all 5. Something like S345 or something like that is the fuse or relay. Should be a 15a blue fuse.I don't have a wiring schematic to hand but by some chance do these 4 electrical devices share the same circuit or connection point at the ecu or fuse board.
