Saturday,18,April,2020,10:29:04:64396
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 20.4.0.1
Data version: 20200331 DS317.0
www.Ross-Tech.com
VIN: WAUZZZ8V7HA065741 License Plate: GJ17NNZ
Mileage: 34179km-21237mi Repair Order:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 47 52 5F 69 BB BC
VIN: WAUZZZ8V7HA065741 Mileage: 34179km-21237miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
69-Trailer -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
Address 01: Engine (J623-CRLB) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 BP HW: 04L 907 309 R
Component: R4 2,0L EDC H23 1198
Revision: B5H23---
Coding: 021D0012032501082000
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_ECM20TDI01104L906026BP 002002
ROD: EV_ECM20TDI01104L906026BP_002.rod
VCID: 79F3FF34F822DE4E45-802C
No fault code found.
Readiness: 0 0 0 0 1
Address 02: Auto Trans (J743) Labels: 0D9-927-770.clb
Part No SW: 0D9 300 041 H HW: 02E 927 770 AQ
Component: DQ250-6F MQB H54 4902
Revision: 06354004 Serial number: TFK01608301205
Coding: 0014
Shop #: WSC 04742 780 00200
ASAM Dataset: EV_TCMDQ250021 001001
ROD: EV_TCMDQ250021.rod
VCID: 1D3BCBA40C4A426E09-8048
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 614 517 AR HW: 5Q0 614 517 AG
Component: ESC H62 0642
Revision: 00000000 Serial number: 62766000000630
Coding: 12F18AA224260A718B7E0E0440C42948512450D170029473026100748208420000000012121212B835351919323200
ASAM Dataset: EV_Brake1UDSContiMK100IPB 036010
ROD: EV_Brake1UDSContiMK100IPB_036_VW37.rod
VCID: 010397D490F2868E0D-8054
Address 08: Auto HVAC (E87) Labels:| 8V0-820-043.clb
Part No SW: 8V0 820 043 Q HW: 8V0 820 043 Q
Component: AC Automat H03 0110
Revision: 20001000 Serial number: 00000001043745
Coding: 03100104002000011000000000001100
ASAM Dataset: EV_AirCondiFrontVaAU37X 008021
ROD: EV_AirCondiFrontVaAU37X.rod
VCID: 408552D0DB784F8642-8014
Relative humidity sensor in fresh air intake duct:
Subsystem 1 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H01 0005
Serial number: 9FF88F4800PAG0MUFU03
Address 09: Cent. Elect. (J519) Labels:. 5Q0-937-08X-V2.clb
Part No SW: 5Q0 937 084 CG HW: 5Q0 937 084 CG
Component: BCM MQBAB H H34 0236
Serial number: 02001627901283
Coding: 000000000000000000000000000000000000000000000000000000000000
ASAM Dataset: EV_BCMMQB 017001
ROD: EV_BCMBOSCH_017.rod
VCID: 7F07112CE606F07E7B-802A
Control Unit For Wiper Motor:
Subsystem 1 - Part No SW: 8V2 955 119 A HW: 8V2 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 160906 043 0580
Serial number: 160916224159
Coding: 0A47F7
Rain Light Recognition Sensor:
Subsystem 2 - Part No SW: 8U0 955 559 C HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0004
Serial number: 62323861
Coding: 00006C
Light switch:
Subsystem 3 - Part No SW: 8V0 941 531 AR HW: 8V0 941 531 AR
Component: E1 - LDS MQB H06 0032
Serial number: 03 08 2016 00000957
Sensor For Anti Theft Alarm System:
Subsystem 4 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
Component: Sensor, DWA 005 0316
Serial number: 000000000ZY162223C3V
Alarm horn:
Subsystem 5 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Component: Sirene, DWA 005 0313
Serial number: 00000000000067223095
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-283.clb
Part No SW: 5QA 919 283 HW: 5QA 919 283
Component: PDC 4 KanalH07 0031
Serial number: 000308419616272
Coding: 0700040011
ASAM Dataset: EV_EPHVA14AU3700000 009027
ROD: EV_EPHVA14AU3700000_009_AU37.rod
VCID: 071789CCBED6B8BE43-8052
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 5Q0 959 655 AR HW: 5Q0 959 655 AR
Component: AirbagVW21 003 0315
Serial number: 003TDR25MCTD
Coding: 98CCC0000C0000005C5400CA00C800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002154
ROD: EV_AirbaVW20SMEVW37X_VW48.rod
VCID: 1025A290CB98FF0692-8044
Side Sensor Driver Front:
Subsystem 1 - Part No SW: ----------- HW: 480 000 610 16
Component: SideSensor_Df 001 0887
Serial number: 357000000007E4CCDE16
Coding: 2D2D2D
Side Sensor Passenger Front:
Subsystem 2 - Part No SW: ----------- HW: 480 000 610 16
Component: SideSensor_Pf 001 0887
Serial number: 35800000000B277C4E1V
Coding: 2D2D2D
Side Sensor Driver Rear:
Subsystem 3 - Part No SW: ----------- HW: 480 401 010 16
Component: SideSensor_Dr 000 6149
Serial number: 3510001A5231F2B294A+
Coding: 2D2D2D
Side Sensor Passenger Rear:
Subsystem 4 - Part No SW: ----------- HW: 480 401 010 16
Component: SideSensor_Pr 000 6149
Serial number: 3520001A5231F2B1B5C3
Coding: 2D2D2D
Front Sensor Driver:
Subsystem 5 - Part No: -----------
Component: FrontSensor_D 001 6149
Serial number: 35500029F218C2A37367
Coding: 2D2D2D
Pedestrian Protection Driver:
Subsystem 6 - Part No SW: ----------- HW: 480 401 908 16
Component: PedP_Sensor_D 000 6149
Serial number: 2280001C121DBA03263Y
Coding: 2D2D2D
Pedestrian Protection Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 401 908 16
Component: PedP_Sensor_P 000 6149
Serial number: 2290001A120F2B2125BX
Coding: 2D2D2D
Pedestrian Protection Driver 2:
Subsystem 8 - Part No SW: ----------- HW: 480 001 209 16
Component: PedPSensor_D2 001 0887
Serial number: I0M000000009E2706E17
Coding: 2D2D2D
Pedestrian Protection Passenger 2:
Subsystem 9 - Part No SW: ----------- HW: 480 001 209 16
Component: PedPSensor_P2 001 0887
Serial number: I0N000000007D0206E1+
Coding: 2D2D2D
Address 16: Steering wheel (J527) Labels:| 5Q0-953-549.clb
Part No SW: 8V0 953 521 HB HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0140
Revision: -------- Serial number: 07101608490083
Coding: A418
ASAM Dataset: EV_SMLSKLOMQB 020002
ROD: EV_SMLSKLOMQB_019_AU37.rod
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 8V0 920 972 L HW: 8V0 920 972 L
Component: KOMBI H04 8316
Coding: 27A509082B8026000100E8001001000000000000
Shop #: WSC 12345 123 61029
ASAM Dataset: EV_DashBoardVDDMQBAB 009054
ROD: EV_DashBoardVDDMQBAB_009_VW37.rod
VCID: 479749CCFE5678BE83-8012
Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 AL HW: 5Q0 907 530 E
Component: GW MQB Mid 127 1265
Revision: -------- Serial number: 0005425667
Coding: 030100041F0873005B0002481C0B00000001010000000000000000000000
ASAM Dataset: EV_GatewLear 013020
ROD: EV_GatewLear_013.rod
VCID: 7BFFE53CF21EEC5E57-802E
Alternator:
Multi Function Steering Wheel Control Module:
Subsystem 2 - Part No SW: 81A 951 523 A HW: 81A 951 523 A
Component: J453 MFL H04 0003
Serial number: 20160824213720 21330
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J
Component: J367-BDMConti H03 1050
Serial number: 75410803001610015096
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 E HW: 5Q0 959 593 B
Component: TSG FS 020 0041
Serial number: 210916EIK10937
Coding: 00518A205C01040000001002
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 438F5DDCCA6E549E5F-8016
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 5Q0 909 144 T HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 128 1072
Coding: 8107
ASAM Dataset: EV_SteerAssisMQB 013144
ROD: EV_SteerAssisMQB_013.rod
VCID: 458B43C4C45A6AAE71-8010
Address 47: Sound System (J525) Labels:| 81A-035-466.clb
Part No SW: 81A 035 466 HW: 81A 035 466
Component: MIB2_amp_P_A3 H10 0100
Revision: 00000001 Serial number: AUZ8ZAGHX00CZH0
Coding: 0173030000AAAA2AAA0000010000
ASAM Dataset: EV_AMPMst16C9Gen2ALPI 001002
ROD: EV_AMPMst16C9Gen2ALPI.rod
VCID: 62C1B85875B43D9674-8036
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 E HW: 5Q0 959 592 B
Component: TSG BFS 020 0041
Serial number: 130916EID22802
Coding: 005182205E01040000001002
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 428158D8D5745D9654-8016
Address 5F: Information Electr. (J794) Labels:* Redir Fail!
Part No SW: 81A 035 192 HW: 81A 035 192
Component: MU-HS-LND-EU 045 0148
Serial number:
Coding: 017303010000000011111102000A00102F002AE601F00100CE
ASAM Dataset: EV_MUHigScl6C3DELP 001011
ROD: EV_MUHigScl6C3DELP.rod
VCID: 5EB98CA841CC197650-800A
Data medium:
Subsystem 1 - Part No SW: 8W0 919 866 C HW: -----------
Component: ECE 2016 --- 0009
Serial number: --------------------
Display unit 1 for multimedia system:
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0014
Serial number: AUZ8Z9GY208EA7
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8V0 919 614 BE HW: 8V0 919 614 BE
Component: ControlUnit_B H50 0103
Serial number: ALJAL126091600010287
Address 69: Trailer (J345) Labels:| 5Q0-907-383.clb
Part No SW: 5Q0 907 383 L HW: 5Q0 907 383 L
Component: Anhaenger H27 0260
Revision: 8C001005 Serial number: 0537757124
Coding: 0100000000000000
ASAM Dataset: EV_TrailFunctGener2Hella 001008
ROD: EV_TrailFunctGener2Hella_VW37.rod
Address BB: Door Rear Drv (J388) Labels:* None
Part No SW: 5Q0 959 595 E HW: 5Q0 959 595 B
Component: TSG HFS 020 0041
Serial number: 260916EIP0952B
Coding: 000082204001040000001002
ASAM Dataset: EV_DCURearDriveMAXKLO 006003
ROD: EV_DCURearDriveMAXCONT.rod
Address BC: Door Rear Pass (J389) Labels:* None
Component: TSG HBFS 020 0041
Serial number: 260916EIP09527
ASAM Dataset: EV_DCURearPasseMAXKLO 006003
ROD: EV_DCURearPasseMAXCONT.rod
End-------------------------(Elapsed Time: 05:11)--------------------------
