Do tell Pie Eyed... i've been struggling to get the leather on the steering wheel back to original, what's the trick?
Ignore this - saw the earlier posts.
What a ******** stole most of your front during lockdown?
yDid some deconstruction ahead of planned reconstruction tomorrow...
Sent from my ONEPLUS A6013 using Tapatalk
Any good tips on removing baked on breakers yard chalk pen. Tried a little WD40 but that's not cutting it (literally)
I've only put on the turbo side hoses so far as I've bought a spare PAS cooler and hoses and am going to see if there's a nicer way to mount it rather than just bend the existing one.
The intercooler fitted without issue but yeah, the hardware kit is cheap as ****. The instructions are pathetic.... going into great detail about removing the bumper but then incredibly vague about everything else. Got my rubber bungs in today for the map sensor, but I know the bolt holes aren't sealed so the whole lot is going to end up siliconed to ****. The wrong size boss for the map sensor is **** considering how long the product has been out, and their fix, sorry their bodge of including the metal adaptor, just doesn't work unless it's sealed.
I expected better. Lesson learned. Would not recommend.
alcohol petrol just make sure u have water to rinse and polish and wax to go straight over the whole bumperAny good tips on removing baked on breakers yard chalk pen. Tried a little WD40 but that's not cutting it (literally)
Yeah the map sensor fitting seems to be the issue they cant fix for some reason or another even though there's an easy solution, I have nothing to compare it to as this is my first turbo car but went solely off the recommendations of the car scene in general as airtec have a very big and strong following in the modified car world and ford fan boys love them so I also expected better, happy now its all on and done but expected a better product overall given there rep.I've only put on the turbo side hoses so far as I've bought a spare PAS cooler and hoses and am going to see if there's a nicer way to mount it rather than just bend the existing one.
Might be the angle or possibly lighting but that's a slight bit offAh the non standard exhaust
I had the same problem when I installed them on my B6 .... I used a hammer and an old small screw driver to break the plastic around the screw ... them use grips to remove the screws ... replaced with self tapers .... once on fault free & look amazing .Just finished changing plate light had standard ones but put led bulbs and didn’t works well, had error on plus they pulse all the time. Order LED ones with no error but couldn’t take screws off... what a job, took me about hour, screw bit round, tried drill first with too small drill bit and didn’t get screw head off then can’t go through screw with bigger one because of bad angle, no much access with bigger drills or screwdrivers, find on few forums to brake old plastics and just grip on screw to unscrew but honestly they making harder plastic then metal screw wtf, first one brake pretty well and got the screw off second one plastic left around screw and can’t get grip on it... had to try cut off plastic round but can’t gets to it.
Thought I'd gone cross eyed from looking at my laptop too much!Ah the non standard exhaust
Available everywhereWhat is this?
if only u could just turn the boxes over as it look like it was put together incorrectAh the non standard exhaust
They were set up right for the body kit that was on the car.if only u could just turn the boxes over as it look like it was put together incorrect
best bet would be to take to a custom exhaust place and see if the boxes could be cut and just flipped over but I'd say that would be to easy. being a audi but they would be able to make something custom if needed and wouldnt be too much damage to your pocket.They were set up right for the body kit that was on the car.
Would it be possible to flip the back boxes?
Current options I can think of:
1. New valance (unlikely as the exhaust placement is odd)
2. New back boxes (not sure what I need)
3. Get a welder to chop off the tail pipes and put them in the right place (can of worms no doubt)
4. Leave the valance off until I work out what to do...
Currently favouring option 4.
But agree @I'm Just Rob. It does look good apart from the obvious. FML its never easy.
There's a polish company on fleabag selling straight line kits for £80best bet would be to take to a custom exhaust place and see if the boxes could be cut and just flipped over but I'd say that would be to easy. being a audi but they would be able to make something custom if needed and wouldnt be too much damage to your pocket.
Also not sure if it's your cup of tea but when I had mine I had both back boxes removed just a nice straight pipe.
wouldnt risk it incase there not a straight fit find your local exhaust place and go have a chat they will give you optionsThere's a polish company on fleabag selling straight line kits for £80
Aye, all good light working well plus no more error on screen. But so much effort with such a small think. I spend less time to take whole front bumper off and replace grill..Did you get them working ok in the end?
I've got a set that I need to put in mine
I replaced my original bulbs with led ones, with in built resistor, then after about 6 weeks there was a smell of burning plastic, and error message, one bulb had got so hot it was all black and charred.Aye, all good light working well plus no more error on screen. But so much effort with such a small think. I spend less time to take whole front bumper off and replace grill..
I've used it for years on steering wheels. Makes them like brand newHave you given it a go yet?
Yvgggggtj k.Mmmmmm....m..............m......mm.m.mmmm.mmmmmmmm..m.n..mm mmm.m.mm.mmk.mm..mmm......My day just got better, delivery just arrived , not as delayed as expected, I've replaced the broken spring a few days ago, practice I suppose.
