Hi if any one can help be much appreciated when trying to start Audi am getting no ticking over just like it's dead but when try ten seconds later it starts just want to get it fixed before it stops all together thanks
Sounds like a strange fault did you get it resolved? I am wondering when you turn the ignition on can you hear a purring type noise (fuel pump priming) I am wondering if this could be an ecu/immobiliser fault. Is this the main key or a replacement key? Also this could be a relay going bad. It defo sounds electrical. Does everything work when key on ie Windows mmi Ect?
