Engine idle when not in car?????
PeteA7S/Back
Derbyshire
So I have been rattling my brain on this for a while and read the manual several times to no avail. When I get in the car and start it I cant leave it running on the drive without it shutting off the engine when I open the drivers door. If I want to defrost the car on the drive I have to sit in it and make sure the door doesn't get opened. I have looked through the mmi options etc and cant find anything on it to stop it from switching the engine off. It has stop start obviously but this is a bug bear that id like to overcome. Anyone know what im missing????
Hi Pete,
I'm sure thats tied in with start stop button?
I've deactivated my start/stop button. When i start my engine and open the drivers door, the engine is still running and no problem at all. I just get the key not in car warning and thats it.
Try plugging VCDS and change the start/stop to remember last state OR deactivate it Maybe that would work?
Wait... I've just double checked on my settings...
Theres a setting on VCDS where you can enable 'Auto start/stop system with engine running and drivers door opened' This needs to be enabled.
Unfortunately, this setting is not on MMI :(
If you're passing by Birmingham at all next week, i can sort it out for you or you can find someone local that would do it.
Hi I've just seen this and was having same issue with my A7.
Silly question probably, but were you in neutral or park? I found that if I shifted to neutral but applied the parking brake the engine kept running.
Sent from my GM1913 using Tapatalk
