I recently fitted an Error Free (Canbus compatible) LED in place of my useless halogen reverse light bulb.
Unfortunately, upon starting the engine I immediately get a bulb error warning on the dash relating to this bulb.
Putting the car into reverse for a few seconds usually clears this fault but it's not a great solution, so I plugged in OBD11 and fired up the app on my phone and did some digging for a solution.
For anyone with the same issue, this seem's to have worked although you do this at your own risk!
09- Central electrics
Long coding
Scroll through pages until you see: Cold Diagnosis (insert light you have issues with)
Untick box
Save
I no longer have the bulb error warning when starting the car from complete shut down, so I have also unticked the box relating to the DRL and Side lights as I plan to replace them when the bulbs arrive.
I'll update this thread when the bulbs arrive and are fitted.
Long coding
Untick box
Save
