Jim Wilson
OK so hoping someone can help here as I'm pulling my hair out
2006, A6 Avante, Front and Rear parking sensors
I have the usual "put into reverse or press sensor button, display flashes and get a long beep"
I have gone down the normal route for testing -
Checked fuses, all OK
Unplug front sensors, test, no good, plug back in
Unplug rear sensors, test, no good, plug back in
Unplug front & rear, test, no good, plug back in
Tried new (second hand) module
Front bumper off, replaced all 4 sensors with new, tested with only front plugged in, nothing
Rear bumper off, replaced all 4 sensors with new, tested with only front plugged in, nothing
I have scanned the car with OBD Eleven, and have listed under faults -
1. Supply voltage for park assist sensor, open circuit/short circuit to ground
2. Supply voltage for park assist sensor, lower limit not reached
and also have under Live data - Ch 4 (resulting distance / vehicle speed and voltage
sensor voltage supply - 1.4v (this seems very low)
Any ideas anyone ?
Does anyone have a wiring diagram with wire colour codes as well ?
Any ideas anyone ?
