Pics with lowering springs fitted
Buxton2901
Hi guys. I'm looking at getting some lowering springs for my bitdi Avant and just looking for some before and after pics if anyone had some please?
Also how much does changing springs effect the ride quality?
Paul
I have a 2012 S-Line 3.0 tdi which was lowered as from new, in fact delivered that way I guess as it's in the code letters that describe the original car. I have no complaints about the ride at all, so I shouldn't think it makes a lot of difference, if any.
I also have a 3.0 TDI S-Line C7. Late 2011. How would I know if mine came with them as standard? Many thanks.
S line cars come as standard with sports suspension and are lower than se spec cars but I am looking for aftermarket sports lowering springs which lower the car a further 10-15mm on top of s line height.
My 3.0 Quattro on Eibachs and standard shocks. I replaced the shocks with new standard ones rather than go aftermarket and ruin the ride quality
Reactions: L111 FAD and Buxton2901
Can't help you with that, sorry, but I think if you asked your local dealer they can look it up and tell you.
OK that's informative. Thanks. I'm possibly going for h+r springs - I want a little lower than S-Line standard height.
I wonder will the h+r springs feel OK on factory shocks?
Reactions: Buxton2901
Just to clarify, my S-Line is lower than other S-Lines and I've been told it was a factory option that shows up in my car details.
That's what I'm wondering too
Well if that's the case I wasn't aware there was a factory option for lower than s line.
News to me
There are 3 types SE spec then s-line which is 20mm lower & also an s-line sorts package that was 10mm lower.
Reactions: blackwood, DonkeyIce and Buxton2901
@Buxton2901 I'd just go for coilovers but then I am biased .
Reactions: blackwood and Bishop187
In the A7 brochure it says S line is lowered 10mm over standard and the black edition is lowered an extra 10mm on top of the s line suspension. Would have thought an A6 would be similar.
A7 3.0tdi 272 Black Edition Mythos Black Tech pack
Im going straight home tonight to check my brochure - and maybe follow up with a call to my Audi Dealer in the morning. Just to clarify.
Im very dubious about toying with my suspension - I'd like to go a few mm lower, but not at the cost of trading top of the range factory parts for aftermarket items with a fraction of the R&D.
My old bitdi was a black edition on s-Line sports suspension (zero cost option over s-Line suspension), it looked rather low but ride was fine on the 20’s, kids and wife never complained it was firm but not crashy. Handling with the sports diff was great
Reactions: blackwood and Buxton2901
Just downloaded the myAudi app.. Registered my chassis number..
Seems I have the S-Line sports suspension.
My car sits on 20" rims, and the ride is super comfortable in my opinion. I still want it a little lower though.
Am I mad putting in h&r sport springs??
Here is the ride height at present...
Screenshot 20200124 114230 myAudi
20190405 004609
20190405 004708
20190404 165833 1579867063998
Reactions: blackwood, Nathan89 and Buxton2901
Reactions: QUIGGS2001 and L111 FAD
Mine isn't high but just think I want less body roll aswell you know
Are those 21" pal? That'd sit very well with a subtle drop
I fitted the H&R springs to my SE seem pretty comfortable to me and its on 20s
Next chance I get I wanna see about the rears if I can do anything with the rubber spring seats as its a bit higher on the rear when on level ground, but the spring seats also locate them in position so unsure what I can do about it yet. Its not the worst thing ever, just something I'd like to sort out of preference.
Reactions: Nathan89, Bulldog and Bishop187
also need to adjust the headlights but I cant get it in the garage at the minute where its flat :sweatsmile:
Reactions: Bulldog
Definitely an improvement there pal! I'm worried as mine has factory S-Line Sport Suspension, are the H & R springs going to bring her down much more...
@88rsr when I had my coilovers fitted my mechanic said he left the rear upper spring supporting disc in on mine but on the instructions it says to remove it so you might be able to remove yours. Should give between 10-15mm more drop.
8C418FD9 1BC4 4B66 B8AB 9F8C29B808DC
2794E77C DD06 45B4 BDF5 970FE3E132CC
06D31603 A34D 4EE4 A292 1EBD22066EE4
@QUIGGS2001 The H&R springs will bring it down to the same height as @88rsr car as the measured drop is normally given for an SE spec car.
7D14881B 10BD 4778 B468 29A4FB15303D
@Bulldog cheers that could sort me right out, admittedly when fitting it was peeing down so I was using my work vans canopy for cover and I didn't really notice it when finished until I saw the car parked on flat ground. But yeah I know those rubber seats are thick so a straight removal would be nice, I just had it in my head they also located the spring somehow too like the hole diameter or something.
In the case of straight removal I might get something like some rubber tubing or just something thinner to protect the spring so its not in direct contact with metal for noise and/or corrosion reasons.
I also thought it would be worthwhile pointing out to someone interested in the same springs to look out for the same thing.
Hmm Hope this won't be a waste of my time & money then... The springs in my car are likely the same size as the H & Rs I'm going to put in?!
In saying that, a pal of mine put H & Rs into his S-Line Quattro A7 last wk and it did bring it down nicely.
Before...
IMG 20200129 221357 026
IMG 20200129 221344 737
After...
IMG 20200129 221311 468
IMG 20200129 221332 599
Reactions: blackwood, Nathan89, V6 Quatt and 2 others
Im looking for some springs also for my A6 to go with 21" wheels.
You bite the bullet yet and done the swap?
Not yet mate still looking for a reasonably price set of springs and convince the Mrs that we need new springs lol
Sorry for bumping an old thread, but how can I find out if the car is Sline, black edition or se exec? I would like to lower my about 20/30 mm and not sure what springs to get.
I think this maybe the right ones but not 100%
Any help much appreciated. Cheers
The S-line and Black Edition should should an an S-line badge under the mirrors. Black Edition will have a flat-bottomed steering wheel, BOSE sound as standard, and black roof rails. Find the build sticker in the boot (sport suspension was a no-cost option on both S-line models).
1BA is SE Exec suspension.
1BE is S-line suspension - lower (-20mm)
1BV is S-line sports suspension - even lower (-30mm)
The part that you are referencing is definitely for a 35mm lowering on a 4WD rather than 2WD.
Reactions: blackwood, Nathan89 and quattrov6tdi
Just reading this thread for research purposes as wanting to lower my 2011 C7 A6 avant I have the SE spec suspension on mine. Could I just get (new) S-line sports springs and it would be direct fit and be lower? Also are the shocks different in anyway?
I have never lowered any of my cars. However, different shocks are normally required to work with lowered suspension. Hopefully some experts will be along to offer advice.
Do you find the SE suspension too soft or is this an appearance-only modification?
I deliberately sought an SE spec car because I value the ride comfort. My driving style for corners is slow in, fast out (rather then fast in, fast out) and therefore it does not wallow too much.
Reactions: Nathan89
Reason for wanting to lower my vehicle is for both looks plus reducing body roll. I'm thinking of a complete set of springs and shocks or coilovers would be the best option now rather than just springs
Basic rule of thumb is that standard dampers OK lowering 30mm but more than that requires matching dampers.
Reactions: blackwood and Nathan89
I swapped out just the springs for Eibach which made a considerable difference to the looks but more importantly body roll and handling. Recommended.
Reactions: blackwood, Nathan89 and Bishop187
What was your original springs?
How much the drop?
How much the drop?
From standard S-Line Black Edition to Eibach.
15-20mm extra drop.
Good enough for me as it feels tighter and more controlled with considerably less roll.
Reactions: Bishop187
