Had a crack at retrofitting the memory seat switch to my cab today. Been following the diy on Audizone (part 1 and part 2) which is pretty comprehensive. Managed to get the door card off and fitted the switch along with a diy wire harness made up of repair wires that connects to the window/mirror regulator motor and the power wires in the door lock switch. The memory seat switch lights up which is good news! Getting the door card on was a pain, seems still to have not properly lined up by the tweeter speaker but I kinda gave up trying to perfect it in the end so there's a little gap. I'll need to try again some day.
I'm onto part 2 of the diy which involves tilting the driver seat back and unplugging the connections under the seat. Here is where I need help...
There is a red plug that I need to disconnect and then take out the red connector base to be able to add two new repair wires in the back of it. I got the red plug out ok but can't get the red base connector out. Has anyone ever taken out that red connector? The diy says to push to small screwdrivers down the sides. It must be clipped in somehow but for the life of me can't seem to pop it out. Limited space under the seat is not helping. Any advice welcome.
Will post my own diy on the technical area once it's all done and hopefully working. Gonna have another go at it in the morning.
Few photos of progress below.
Sent from my Nexus 6 using Tapatalk
