Starting first thing ..lumpy start
guyzza75
SOUTH WALES
Hi there audi a4 b7 2.0 tdi 140 bhp..Starting to get lazy first turn of the key..spins over fast and fine then fires a bit rough but when starts it's fine.. the rest of the day runs like clockwork, no misfired no lack of power etc..once started once will start all day.
I have changed tandem pump , new Bosch glow plugs, new coolant sensor (TPS) and placed a non return valve online between filter and tandem pump , however still a pain to crank first thing....Any ideas? Thanks in advance
For anyone else that has this, I have changed lots of things to eliminate this issue and I believe it was the "T" piece that fits into the fuel filter. I bought a new one from a well known online auction site which came with new o rings and the car is currently starting great! Was about 8 quid. Top tip - place some vaseline around the o rings before pushing back in the top of the filter, as this stops them twisting and provides a better seal. It appeared I had air leaking in overnight and causing diesel to run back to tank... hope this helps someone as a cheap fix rather than spending the amount I have
Reactions: tr7, ANDY2.0 and BakPak
Thanks for your feedback! My B6 1.9 PD130 I think is the same as yours was. I’ve fitted a new battery and glow plugs, it has plenty of power turning over just has a ‘stutter’ half way through start up on some mornings.
Do you have a link to the T piece you bought please? Will find the equivalent for mine if it’s not compatible, once I know what I’m looking for.
Hi @guyzza75 Any link please?
One of mine is giving this sort of issue and would like to rule it out
