Better than yellow stuffs? How much can you get them for!? I can get them fitted for fairly cheap. Would be nice to get some for a good price!!Redstuffs are perfect.
Decent!Reds - you aren't using on a race track are you??
https://ebcbrakesdirect.com/automotive/audi/rsq3-8u/2.5-Turbo-Performance-2016-/1000314
£200 for the fronts (that's actually 8 pads)
£61 for the rears
I’m looking to order a performance drop in panel filter but can’t find a really decent one. Only decent one I can see is an APR one. Worth going for??
I normally remap everything Vans and cars, But not this one , (I must be getting old) Its fast enough , WoW did I just say that , Ha ha, Good fast car,sI've pondered a REVO remap a couple of times on the wistful logic of 'because I can' but truthfully I've never got in the RS and thought 'this isn't quick enough' so have never pursued it. It would only eat tyres even faster and test my powers of restraint still further. Expensive though it was the Cete AVC has been the best mod (aside from EBC Redstuff pads) it sounds faster even though it isn't - that visceral 5 cylinder howl is just so intoxicating.
Did you do them all around or just the fronts ??Reds - you aren't using on a race track are you??
£61 for the rears
Annoying - it's probably implied worry by the dealer over being reimbursed. If it's inside cover then you ought to be fine. Is the dealer that's identified the repair requirement the same one that supplied the car?
Hi,thanks for the reply. No,it isn’t,I was so unimpressed with the service department when I collected my car from the dealer I purchased it from that I thought I try a more local franchise. Would that make any difference to the claim?
Should make no difference
My last SQ5 had the dreaded sun roof rattle , Days before the warranty ran out York Audi took the car in to repair it, They were good, Kept it until all new parts came and completely overhauled it , got it back a week later all done, So tell the dealer to keep your car until all faults done, otherwise youll end up paying. If out of warranty.
Yep had a new Q5 Petrel For 9 days, All I did was drive it home park it up, Then back to York Audi, When my car was done, Ive found they Do the warranty work faster if you have a loan car,
Garage I use will fit these for £36 fronts £36 back. Good price, ??Reds - you aren't using on a race track are you??
£61 for the rears
My RS will have them fitted at 10K, So should last a bit, (I hope)Good man, absolute no brainer on an RSQ3 when the standard discs have a 2mm wear limit (so 1mm of each face) and they are around £500 a pair, add the lack of wear (just polishes - see pics above, fitted at 15k miles, the disc already had a lip), noticeably increased brake performance and low dust once bedded in - not much not to like.
Nice one chap, bet you’re buzzing with it? How much was it all in and did they also alter the rear valance to suit? Does it sound mint then? Definitely get some pictures up and sound clips as soon as you can!Got my RS back today, With twin exhausts, Workmanship Looks 100% at first glance , will know better tomorrow, When I get under the car, The 2 rear pipes out back to me make my RS, Pics when I can, >> The sound is 100% RS.
Naylor, You would like the noise !!!! Yes he trimmed the rear valance, Cost £350 all in ,
I know I would! Get some pictures and videos up sharpish chap. Mega! That’s a mint price for everything all in. I’ve swapped my standard exhaust for a PCW modded one with valve controller now and waiting to get it fitted when I finally get my car back next week! But definitely want the twin pipes at some point for sure. Looking forward to seeing yours!Naylor, You would like the noise !!!! Yes he trimmed the rear valance, Cost £350 all in ,
Put 1 pic in gallery , struggle with getting them on here,
Looks great, much better than one pipe, but I think the tips need to be tucked in a little more so they’re about 10mm from sitting flush with the bumper
Pic of RS3 above looks good to me, My RSQ3 has the same spacing and that looks good Too, As always we all mod our cars as we want them.Hmm,I’m actually thinking I still prefer the single pipe personally. As previously posted,I think they both need to be “right into” the outsides of the diffuser as on the RS 3/4/6. Ultimately,it’s your car,and if you’re happy that’s all that matters
Its the angle of the photo, It is 10mm from sitting flush with the bumper. And much better than 1 pipe thanks.
£61 for the rears
