Perhaps, but it could also be part of the MMI system (which I suspect) as I think it turns off after 10 minutes with no ignition like the rest of the MMI. I'm sure I tested it before anyway and it did this.
by default the 12V socket only comes on with the ignition - but it turns out it's very easy to make it a 'permanent on' socket.
My 8P is permanently live. While I want the Inverse to be true in my 8V (always live), do you know whether it is possible to make non-permanently live in the 8P, i.e switch off with ignition?Apologies for digging up an old post, but I only recently discovered this and wanted to say thanks!
It was one of the things I missed about the 8P and I find it very useful, and even with a few odds and sods plugged in all the time (TomTom and various USB adaptors) I haven't noticed any battery drain issues
Just a quick note, as nobody had actually confirmed this works: I finally got around to trying it at the weekend and it works a treat - no longer do I have to switch the ignition on to pump up the tyres!
I know there are some on here who wanted this, as by default the 12V socket only comes on with the ignition - but it turns out it's very easy to make it a 'permanent on' socket.
I discovered this completely by accident while wiring in my dashcam today. The fuse for the cigarette lighter is apparently movable depending on which option you want (I think Peugeot do this too, I have heard anyway). I haven't actually tested this myself however, but only discovered the functionality while poking around the fusebox with a multi-meter today.
Here's a picture of my fusebox, which can be found by removing the panel at the back of the glovebox - there's a finger hole there to make it easy:
If you look just to the right of the 2 15A fuses (the blue ones), you'll see a 20A fuse (yellow) that seems to be going between 2 rows of fuses. I looked up the fuse in the manual to see what it was, and it's the fuse for the lighter socket / 12V socket. The reason for this is because the fuse can be moved depending on whether you want 'on with ignition' or 'on permanently' mode for the the socket. As it's shown there, it's in its 'default' place of on with ignition only, but if you were to move it up half a fuse-length to be in line with the 30A and 40A fuses on the row above, it would be permanently on. I've confirmed with a multi meter that the contacts above the fuse are permanently on and the lower one (the one that the bottom of the fuse is currently in) is on with ignition only. The middle contact (that the top of the fuse is currently in) goes to the socket itself.
Like I say - I haven't actually confirmed it 'end to end' as it were (as I have nothing to plug into the socket anyway!), but I hope someone finds this useful. It's certainly an undocumented feature!
Wow that’s a great find . Do you know what fuse is for the phone box. My wireless charging phone box doesn’t seem to be working.I know there are some on here who wanted this, as by default the 12V socket only comes on with the ignition - but it turns out it's very easy to make it a 'permanent on' socket.
