Driveshaft bolts torque
slepy
Extremely smart and handsome person.
Leicester
Hi all.
I'm trying to find the torque for the six bolts that join driveshaft to gearbox/transfer box. Spline bolts. I have elsawin but can't find this anywhere. All it says is the main hub bolt.
Asked at audi today but they weren't very helpful either.
2010 S3 8P
2016 Audi A3 1.6tdi SE Technik
2007 Supercharged 365bhp Civic Type R
Depending on the size of the wrench one might be tighter than the other so would like to get this right ;)
Code:
12 -  Multi-point socket head bolt
q    Always renew if removed
q    Initial tightening torque: 10 Nm in diagonal sequence
q    Tightening torque, M8: 40 Nm in diagonal sequence
q    Tightening torque, M10: 70 Nm in diagonal sequence
in elsawin its listed under running gear/driveshafts/Servicing drive shaft with 108 mm dia. inner constant velocity joint
Thank you
995
KKM
693
NHN
