Hello,
BAM engine, existing Mods;
- Complete 3" exhaust
- Decat
- F23 turbo
- Stainless exhaust manifold
- Mushroom air filter
- Badger5 TIP
The head has been refurbished, new water pump timing belt etc, compression is good on all cylinders.
I have 440cc injectors, up-rated fuel pump & new fuel filter but haven't installed these yet.
Running Shell V-Power (99)
I think I'm getting to the limit of this hardware setup before something breaks with this home produced map.
I have a problem at about 6600rpm the revs throw a wobbly (feels a bit like rev limiter kicking but softer), I'm thinking it could be the spark being "Blown out", but I'm not seeing any misfires, would "spark blowout" register a misfire?
(no need to explain "spark blowout" I've read the different explanations (ones that say the arc dosen't even get started and the ones that say the arc get's "blown out"), hence the "quotation marks")
The plugs are gapped to 0.7mm, rpm limit set 7200rpm, full log attached.
Any Ideas most appreciated.
- Decat
- F23 turbo
- Badger5 TIP
